Bronze Member Username: Kaprese
Walstonburg,
NC
Post Number: 96 Registered: Mar-07
Posted on Alright is there any possible way to hook up 2 amps to 1 subwoofer |
Silver Member Username: Mike11202
DE
US
Post Number: 295 Registered: Nov-06
Posted on Yes.. strapped |
Gold Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 5852 Registered: Jun-06
Posted on Make sure the gains are set identically. |
Gold Member Username: Stnorris
RE SX 15,
IA
US
Post Number: 2140 Registered: Apr-06
Posted on ya and make sure the amps are strappable and that u have the right load |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 11999 Registered: Dec-03
Posted on either strapped, or with one amp per coil if the sub is DVC or QVC |
Wisteria,
Lane
Post Number: 12000 Registered: Dec-03
Posted on theoretically, you could strap pairs of amps for each coil of a quad coil sub, like an RE MT. 8 amps on one sub |
Walstonburg,
NC
Post Number: 97 Registered: Mar-07
Posted on OK I was just asking because a friend of mines had wanted to know and see if he could pull it off |
