Logan aint got sh1t on me
Username: Drivingreckless
DD 9515f, 146.2 db Mov...
Post Number: 3265
lets see if you can handle this logan....
snd rob IT WAS EASY!!!
3.5 tuned to 33hz with a flared slot port
Username: Mygame5982
I Got Serious Wang H-..., TEXAS US
Post Number: 1679
super nice
Username: Nyyfan13
Fi SSD USA
Post Number: 4735
good job driving...
Username: Splmonster
Nowhere, OH USA
Post Number: 722
looking good f@g, now make me one
Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1348
wow, you did a nice @$$ job on that bend.
your work is real clean, i like...
Username: Safe_cracker
Chicago, IL US
Post Number: 2615
Real nice but where ya planning on putting the sub? Polo..
Post Number: 3268
subs up, ports back
thanks for all the positive feedback
Post Number: 1355
pics of the back of the bend? and what is the extra 4 or so inches on the left side of the first pic?
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1591
daaaaaaaaaammmmmnnnnnnnnnn!!!!
Post Number: 3269
dont feel like takin any more pictures
its another 6"s so it hits my battery to make it look cleann
Post Number: 3270
hides*
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6951
Your on Dave!!!
Username: Nyyfan13
Fi SSD USA
Post Number: 4736
since when do you care about looks driving? lol
Username: Spkrman
Chi town, IL U S A
Post Number: 419
yep you guys can quote me... 2007 = the year of the flared slot :-)
Post Number: 3273
"since when do you care about looks driving? lol"
since i realized your mother is gettin fatt
nah mark i just didnt wanna pay 200 dollars for a flared slot port from TCAB
Username: Nyyfan13
Fi SSD USA
Post Number: 4739
lmao your such a d1ck drivin
Username: Spkrman
Chi town, IL U S A
Post Number: 420
the TCAB design is more than a flared slot :-)
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1594
driving its mssin sumthin that all ur otehr boxes seem to use..........
..............duct tape!
Post Number: 3274
like i sed
"i just didnt wanna pay 200 dollars for a flared slot port from TCAB"
Post Number: 3275
"driving its mssin sumthin that all ur otehr boxes seem to use..........
..............duct tape!"
im gunna carpet this one :-)
Username: Nd4spd18
Southeast PA
Post Number: 1545
" lmao your such a d1ck drivin "
Yeah he is but he's dam funny.....
Username: Nyyfan13
Fi SSD USA
Post Number: 4740
yes he is...i cant deny that
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 452
ok my ? is how do u get wood like that to bend?
Chicago, IL US
Post Number: 2616
Nice 1st one now when you building the 2nd? With all them sharp corners in that port the flair really isn't gonna do much but it sure looks a heck of a lot better, lol. Polo.. :-O
Username: Oglejust
Post Number: 1419
thats nice dave
Post Number: 3276
lol
no polo
this is my first and last daily driving box!
but i got a few more spl designs i wana try
im not a d1ck
Chicago, IL US
Post Number: 2618
Dude, You are a D!ck!
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4121
nice dave... better than i expected lol. make 3 caddy corners and sand those sharp corners down a bit. you should have the 95 soundin real nice.
Los Angeles, CA USA
Post Number: 12094
nice. the box looks clean.
Username: Matt12490
California USA
Post Number: 2222
I want to try that, but where does the actually port start when you are deciding port length. I am guessing from where it starts to flare out is the "end" of the port??
Username: Andrew571
Post Number: 780
looks good bro
Post Number: 3277
i was reading TTB and in thier archieves it says caddy corners do not boost spl and take away from the port volume...so thats a no go...
i used the flare as part of the ports lenght
thanks guys for all the positive feedback
Post Number: 6954
Im going to make a better one today:-)
Los Angeles, CA USA
Post Number: 12097
the more i look at it the more i like. mad props dave.
btw don't screw it up later by running your sub cables out the port. :-)
Username: Trey4sports
Post Number: 988
dam driving that is very nice craftsmanship.
Post Number: 4123
go read the TTB thing again. it doesnt help SPL but helps with achieving a flatter response. so if this box is for SQL thats what you want. also, common sense should have told you that every TTB box youve seen has caddy corners ;)
Username: Spkrman
Chi town, IL U S A
Post Number: 422
caddy corner, yuck. Sounds kinda... "sweet".
45's in the corners of either the box or the port may or may not help... it depends on the size, tuning, port area, vehicle, placement, power, and your desired freq response.
45's generally DO help spl, albeit very marginally and nothing you could ever hear... at least in all but the most specific cases.
Just like resin has its place... 45's have theirs.
Username: Johnfiac
151.9db Dail... My wangers b...
Post Number: 2299
How do you make the bend like that? I know the wood doesnt just bend... it would snap, do you place a board on a angle then sand\putty it?
Post Number: 6956
lol cut small slits in it.
Username: Fi_car_audio
Hades, NV
Post Number: 127
its called "kerf" cutting. You run a bunch of cuts most of the way through the board at a specific distance apart (depending on the desired radius of the bend). Larger radius= more width between cuts. Then you can fill the kerf cuts with wood glue, resin, whatever makes you happy and it sturdy (fill beofre bending and smear the ooze over the rest of the back).
On the 45s... they can help in certain situations and in general are not bad prcatice to use (yet to see a proper one hurt). Same goes for resining things too.
Thanks,
Scott
Username: Adddisorder
West palm, Florida
Post Number: 4025
looks like driving got jealous of mine
have to say though it looks good not near as getto as all your others
West palm, Florida
Post Number: 4026
and for anyone wondering on how to calculate the flare and port length, half of the flare width add to the end of the port length
Post Number: 4125
nice.
how do you like your mag? whats the box size/tune?
i just installed mine in a sealed box and am very impressed... i cant wait to install the 2 of them in a TTB box...
Post Number: 3279
i finally put it in ill get pics tommorrow...
BTW sounds LOWWW
West palm, Florida
Post Number: 4035
quote:
nice.
this one is 2 at 30hz and i love it the lows and the SQ are awesome. i ran it sealed 1.25 with polyfill and it was nice but the ported is alot nicer, the SQ is still amazing but the lows KILL
Post Number: 4157
Good to hear 8)
I cant wait to port mine. I really dont know what was wrong when people were saying they arent that loud and are muddy.... mine is quite beastly sealed and the SQ makes me want to put my d!ck in it, i mean its d!ck in me, i mean...
if you havent seen beer fest disregaurd the last sentence lol. if you have and cant remember.... when they taste the beer from the secret recipe for the first time....
Post Number: 4159
Dave, i just frequented the hexibase forum... you cant even beat a pair of RE8s you pune! petes hittin 147.1 and your highest score was 146.2 but when i saw you you hit 145.3 or sumin lol.... I'm jus messin with ya lol. but go check it out. he built a SPL hellboy. he thinks if he switches the Re8s with the Rlis he might gain around 2db... thats sick... but that design is no good for daily... his daily SQL setup with the rli 8s is hittin 144.8 though. thats baddass
Post Number: 3290
screw you trevor
dont h8 dont h8 dont h8
Post Number: 4160
I'm not "heighting" just making a fun way to tell you about it lol. go check it out for yourself
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 779
Damn Mat that looks really good. I want one now.
Username: Jblanford
Post Number: 790
matt it looks like you cut the slots in the wood a little to far apart
Username: Winterfreshpimp
Chisago, MN America
Post Number: 449
how do you do that? the flare....
Post Number: 3291
yes i know the carpet looks horrible,
the sub ring looks bad from all the ductape
but i love the sub...hits so lowww i gotz to make a video :-)
Post Number: 4164
you just couldnt have a clean box now could you!? lol a sharper blade could have really helped ya out. oh well its the sound that counts. I'll have to listen to it sometime.
Username: Bump05
CashMoney, 15 Hd3 USA
Post Number: 1062
lmao a good start to a sh1tty azz ending lol cmon dave
Username: Johnfiac
Post Number: 2310
How would you calculate how far apart each cut would need to be for the bend? ANd how wide each cut would need to be, and how deep? Could i use a radial saw and just have it cut like 1\2way into a 3\4" MDF board? Place them about 1\2 apart?
Username: Johnfiac
Post Number: 2311
GIMME YOUR BATTERY! :-)
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2010
Nice box, Dave. Before you f*cked it up that is. Dumbass... Just paint the whole thing black like Mat, but this time do a lot better job painting it.
West palm, Florida
Post Number: 4050
like where the port bends? i cut it fine so it is 5.25" of flare
not sure if your saying my paint job looks crappy but its glare from the sun
and DAVE you should have left that box naked or something, you killed it
Username: Wolf_hound
Post Number: 176
Killa heres a tutorial on flared slot port but this guy didn't bend it much for some reason. http://forum.realmofexcursion.com/showthread.php?t=23802
Post Number: 2012
No, your box looks tight Mat. I told dave to paint it black, but actually do a good job painting it because his blue paintjob looks like sh!t, haha.
Username: Th3pwn3r
Post Number:...
Post Number: 2019
Ew.I almost want to cry.You should have left it bare MDF.Would have looked so much better.What were you thinking with that blue paint?To think I was proud of you for a second :-(
Username: Mgbcs
Lincoln, Nebraska
Post Number: 940
oh man...
I don't have anything else to say...
Username: Redliner
Wilmington, Ma
Post Number: 3734
lol i think everyone is thinking the same thing about dave's box.
dave i guess you are an idiot lol
Username: Andrew571
Post Number: 783
ROFL that thing looks like garbage.
lol im jk, wait... now im jk about jk...
so anyways i hope it sounds good, cuz it looks terrible... lol
Username: Nyyfan13
Fi SSD USA
Post Number: 4770
oh wow drivin...you found a way to turn an incredible looking box into a horendous looking thing...
thats impressive that yuo could make it look that bad...you have to try to do that...
nice box building, bad carpeting/painting (was that even paint) lol
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1338
Theres a certain type of wood that can bend like that my dad was telling me about hes not here so cant ask him and remey was using it on Unique whips too....
but thats a good tutorial
Post Number: 3293
come on guiys it doesnt look that bad :-(
like i sed i HATE carpet...it sounds goodat least thats good right???
Username: Mgbcs
Lincoln, Nebraska
Post Number: 943
That's right...sound is most important.
But looking good would be a BIG plus in my book...
Username: Th3pwn3r
Post Number:...
Post Number: 2024
You also should have came all the way up with that side piece that you're using to conceal your rat's nest of wires.
