Better woofer wiring diagrams
Username: Skibum12189
Cleveland
Post Number: 446
i've been using rockford fosgates but they dont have anything for dual 1 ohm subs, thanks guys, shoot me a link please
Cleveland
Post Number: 448
bump it up someones gotta know of one
Username: Dakangofkrunk16
Earth
Post Number: 529
under the fosgate webpage go to wireing formulas and use the formula to figure it out cause i dunno were to find it i htink it will give u a .5 ohm load or usmtin around there i dont feel like doin the math
Username: Solobaric4life
Seminole, Al United states
Post Number: 572
used to have one at www.sounddomain.com
Cleveland
Post Number: 452
ok any better ones??
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 551
what do u want to know man just say it and me or omeone else can tell u ur possiblilties
Username: Rovin
My 1 12 Atom...
Post Number: 11282
basic rule :
wire coils in series u double the ohm
wire coils in parallel ohms load cut in 1\2 .....
Username: Jblanford
Post Number: 776
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?amptype=mon o&suboptions=Mono%5F1%2D2ohm%2DDVC
is that what you're looking for ?
Cleveland
Post Number: 464
well i was looking for how to wire 2 dual 1 ohm subs but then i totally forgot i was just wiring 2 dual 2 ohm subs to 2 ohms soo haha kinda basic but total mind blank, thanks for the help though
Username: Oleg
Santa Monica, CA USA
Post Number: 860
coils in series, woofers in parallel for 1ohm load. coils in parallel, woffers in parallel for 0.25ohm load. coils in series, woofers in series for 4ohm load.
