New member Username: Jmp21United States Post Number: 9 Registered: Aug-06 | hey well i'm wanting to put a system in my camaro, right now i dont have a whole lot of money to put into a system, so im putting my trust in all of your expertise, im looking for the best system possible for $200 dollars or less... i already have a 'decent' head unit so i just need an amp and sub(s) any ideas?? thanks justin |
Gold Member Username: CtmikeCt. Post Number: 3882 Registered: Feb-06 | ideas? save more. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2503 Registered: Jan-06 | $200 is not a lot for subs and amp. Just my opinion, but I would buy 2 pretty good subs for $100 each, and save up for the amp. |
Bronze Member Username: Jmp21United States Post Number: 11 Registered: Aug-06 | ha so do u think i can get any kind of decent system for that much? |
Gold Member Username: CtmikeCt. Post Number: 3885 Registered: Feb-06 | maybe a best buy or circuit city special. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 2507 Registered: Jan-06 | anything for that low isn't probably gonna be decent for instance, my setup 2 RE8 subs normal price $100 each 1 custom built ported box...self built price, one sheet of mdf $30 1 Phoenix Gold Xenon 400.1 amp normal price $269 now thats not including shipping...so $599+Shipping, thats what it would cost IF i paid full price now, heres what I actually paid 2 RE8 subwoofers in custom ported box $175 Phoenix Gold Xenon 400.1 amp $135 My price $310 Now thats 2-8 inch subs, which are small, and a 425 watt amp. IF you go with bigger subs, you need a bigger amp, and it will cost more. |
Silver Member Username: Freezeman_7Lindsay, Oklahoma U.S.A Post Number: 888 Registered: May-06 | maybe^^ or buy something thats gonna blow up in 2 weeks, save up and but nicer stuff |
Gold Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 5485 Registered: Jun-06 | Pep boys has a wonderful selection of combo deals that would compliment your $200. They also sell air fresheners. |
Silver Member Username: SplsqChesterland , Ohio USA Post Number: 143 Registered: Mar-07 | hey check out this site one of my friends got a bought his L5 from here for like 100 shipped. then buy a amp from this site something real cheap. and build ur own box idk thats all can think of with that type of budget. SUB: my friend has one of these ported and it pretty good http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1408922/vpcsid/0 /SFV/30046 AMP: this is something cheap like Pyramid or Boss or ne off brand. http://lib.store.yahoo.net/lib/millionbuy/amplifier.htm |
Silver Member Username: Adam_s15 TC9 Hybrid, RE MT Softparts Post Number: 975 Registered: Aug-04 | I would just not even get anything and just save up until you can afford something that would be worth it. |
Bronze Member Username: FootballaPost Number: 29 Registered: Apr-07 | haha jus go to wal-mart. |
Silver Member Username: SplsqChesterland , Ohio USA Post Number: 146 Registered: Mar-07 | hey if i wanted a system now and had that much money and couldnt spend ne more i would prob get that cause its better then walmart S H I T. |
Gold Member Username: CtmikeCt. Post Number: 3887 Registered: Feb-06 | not by much though^^. |
Silver Member Username: SplsqChesterland , Ohio USA Post Number: 147 Registered: Mar-07 | what would u rather have HONESTLY...one 12inch Kicker L5 or 12inch Lightning Audio or Sony XPLOD....Come on theres no thinking about it. the only thing is ud be underpowering the L5 so bad. I have 2 12inch L5s but im powering them just right and the slam!!! |
