SD2.5 = which DD?
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1263
Which DD is closest to the Audioque SD2.5?
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 804
i beleive the 1500 series
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 495
i think 2500/3500
Username: Nyyfan13
Fi SSD USA
Post Number: 4584
i always equated them with the 2500 series...but thats just me
Username: Mgbcs
Lincoln, Nebraska
Post Number: 765
Well price wise the 1500 and 2.5s are the closest...
Midland, Texas U.S.
Post Number: 496
well dd is a lot more expensive then AQ so comparing price doesnt really work between the two
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6809
Its comparable to the 2500
Username: Snarl2004
Post Number: 805
does ne1 no about how much the 3512's are?
Username: Nyyfan13
Fi SSD USA
Post Number: 4590
about 389 for the 15 i believe but hornets nest and his affiliates are selling the 3515 for 200 a piece...check out the "big bang list" thread...about 1/3 the way down on the archive list
Los Angeles, CA USA
Post Number: 11851
i was under the impression that the sd2.5 = dd3500 and the hd3 = dd9500.
Username: Trey4sports
Post Number: 923
ehh im not that generous. i think the sd2.5 has power handling along the lines of the 1500 series but the HD3 is much closer to the 9500 series than sd2.5 is to the 3500 series
Username: Imalik
SD2.5, New Jersey Ocean
Post Number: 215
Yanks& Logan are correct the SD2.5 is close to the 2500
Username: J_baby15
DiRtY 5oUtH ...
Post Number: 1499
SD2.5=2500
I can get u a 3500 for that price tho, like he said 3500s=$200
Username: Nd4spd18
Southeast PA
Post Number: 1327
SD2.5 = DD 2500 in terms of power handling and loudness
