What to run these with?
Username: Lightning_2001
TEXAS USA
hey guys i am a total noob to car audio but this is what i got to work with till i get some $$.(traded a tire to a buddy for them)
[IMG]http://i140.photobucket.com/albums/r10/lightning_2001/Photo_040407_002.jpg[/IMG]
[IMG]http://i140.photobucket.com/albums/r10/lightning_2001/Photo_040407_001.jpg[/IMG]
my question is what kind of amp should i get for these?i would like to get an amp that i can use with say a 10 w6v2 later on.also what else do yall recommend i get(besides new subs) even other brands in same category as W6.thanks in advance. Jorge
Username: Bernymac
Cambodian
Post Number: 2383
The JL w6v2 will sound very clean. The CVR's will get pretty loud. Ask your friend if the subs are dual 4 or dual 2 voice coils. If he doesn't know, take the sub out and look in the back of the sub to find out. Then we can tell you what amp to get. But, you will need a amp that does 800rms.
TEXAS USA
they are dual 2 voice coils.
Username: Bernymac
Cambodian
Post Number: 2396
wire you subs up like this http://www.rockfordfosgate.com/rftech/woofer_wizard/2_2ohmDVC_2ohm.gif and then get a kicker 750.1 amplifier. They should work well together.
Username: Bernymac
Cambodian
Post Number: 2397
http://cgi.ebay.com/NEW-07-MODEL-KICKER-ZX750-1-MONO-AMP-750W-REP-KX600-1_W0QQit emZ180103844594QQihZ008QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
TEXAS USA
thanks for the help berny.so as far as wiring goes, what do you think id need?
TEXAS USA
would 750 watts be enough to use on a JLw6 down the line?id like to get a good enough amp to keep when i switch subs.
Username: Bernymac
Cambodian
Post Number: 2398
yes, if you get two jl w6's make sure they're both dual 2. If you only want one, make sure its dual 2, wire it in series to get 4 ohm load, that amp will do near 1000 watts. so pretty much your good to go. the jl w6v2 can only handle 400rms so yeah.
TEXAS USA
Post Number: 8
"wire it in series to get 4 ohm load"
do you mean like in the diagram in above post?
Username: Bernymac
Cambodian
Post Number: 2400
no, when you only have one sub woofer wire it to 4ohms (series). But when you have two subs, wire it to 2ohm load.
TEXAS USA
Post Number: 10
thanks again bern.now imma go downtown and see how much i can get the amp for.
Username: Bernymac
Cambodian
Post Number: 2401
your best bet is to buy it online. that link i gave you, you should buy from theres. its probably the cheapest you will find.
