Cotton in box?
Username: Quirky
SA, Texas
Post Number: 87
When I removed the subs to re-cox my new sealed box that i recently bought I found a ton of cotton in it. I've never heard of putting cotton in the box before, what dose it do?
Username: Mrskullz1
Brooklyn, New York
Post Number: 50
its called polyfil...or should be polyfil tho other types of 'cotton' will do such as the stuff thats in ur pillow (thats what i had as a ghetto rig lol)
it basically makes ur sub hit harder....sorta tells ur sub that there is more room than there actually is in the box...
A pic is worth 1000 posts!!
Post Number: 5280
That's called damping. It's used to compensate box volume shortcomings. It absorbs sound thus increasing the "preceived" volume of the box. I've used carpet padding in my speaker enclosures with great results. Cheap too.
Username: Quirky
SA, Texas
Post Number: 89
k thxs, ill keep it in.
Username: Cenus
Hicksville, Ohio
Post Number: 3064
just to clarify it doesn't "absorb" sound it just merly slows down the sound waves, which makes the sub think its in a bigger box.
Username: Skies
Courtenay, British Colu... Canada
Post Number: 514
Has anyone experimented with different materials?
Would like to know what works best :P
Username: Dakangofkrunk16
Earth
Post Number: 393
i got these two bazooka 4 free a long time ago i opened the box and there was a pillow in it lol
Username: Quirky
SA, Texas
Post Number: 90
"Adding Poly-fill in this case will give you a little deeper bass, but may slightly decrease your power-handling capability"-crutchfield.com
does this mean that i will lose spl when it says "power-handling"?
Username: James1115
Use a simple...
Post Number: 9997
no
Username: Shade
Moxee, Wa U.S.
Post Number: 182
but does it add power handling?
Username: James1115
Use a simple...
Post Number: 10003
no
Username: Sinful_systems70
Post Number: 571
It makes the enclosure function as if it were larger than it actually is. So if your box is too small for subs, mainly because of lack of space, you can put that material in the box to make it seem bigger for the sub.
Post Number: 572
Sorry, Paul already answered correctly.
