Bad amp?
Username: Jme_s
i have a 1600 watt logic soundlab amp. i had a 12 inch kicker solo baric hooked up to it. when i first had it it hit very hard then after 3 months or so it just was not the same... so i got 2 brand new pioneer premier 12's model TS-W3004SPL and the same thing... is my amp just bad? is that why my subs are getting messed up i need some help
Username: Ctmike
Ct.
Post Number: 3791
whats the specs on the amp? and please post rms, not peak. sounds like you possibly clipped the kickers to death and then did the same with the pioneers. did you set the gains yourself or a shop?
Username: Jme_s
the amp is 800 wtt rms and what does it mean to clipp subs? and how is this possible when the amp is a 800 watt rms 2 chanel and the subs are 1000 watt rms each with a 3000 watt peak? the subs are no older that 1 month can i return them is it a good idea?
