New member Username: Bholt30Union, Kentucky United States Post Number: 2 Registered: Mar-07 | I was going to buy 2 jl w6v2 in a sealed box and was wondering if i should buy 2 jl 500/1 amps or just buy one jl 1000/1 amp or is there any difference |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11755 Registered: Dec-03 | I'd go with the single amp just for simpliciy sake |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4322 Registered: Dec-05 | me too. But two amps will flow more current. |
New member Username: Bholt30Union, Kentucky United States Post Number: 3 Registered: Mar-07 | which would be better a ported or sealed box for two w6v2? |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 675 Registered: Oct-04 | Two 500/1's will not flow more current. They are good at doing very close to rated power. About 532w per 500. Very little rise between 1.5-4 ohms, unlike unregulated amps. |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11089 Registered: Jul-05 | i too would prefer 1 amp instead of 2 .... |
Gold Member Username: 420alldaylongPost Number: 1212 Registered: Sep-06 | Out of those two amps go with the JL 1000/1. But to save money and get a badazz amp go with a Soundown SAZ1500D just keep the gain under control.http://www.sundownaudio.com/ |
Silver Member Username: JeromebakerPost Number: 102 Registered: Dec-05 | ...That sundown must be one h ell of an amp for it to go for $700. I've seen more than a few JL 100/1's cheaper than that. |
Gold Member Username: 420alldaylongPost Number: 1217 Registered: Sep-06 | SundownSAZ1500D=$450 at low-Hz.com |
Gold Member Username: 420alldaylongPost Number: 1218 Registered: Sep-06 | And yes it is a BADAZZ amp. I'll take SAZ1500D over the JL Audio 1000/1 any day. |
Gold Member Username: HockeyknightPost Number: 1032 Registered: Apr-06 | ^^^^^^^^^^x2 |
