Which sub!!!
Username: Sexybrenty
Post Number: 13
= i found out my rockford fosgate 450.2 amp has this:
RMS Power Output:
4 Ohms: 100 watts x 2 chan.
2 Ohms: 225 watts x 2 chan.
4 Ohms Bridged: 450 watts x 1 chan.
what would be the best sub for it and what should i do with it?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11921
budget
Post Number: 14
budget for sub would be about 200 but owuld prefer just one twelve inch or maybe two tens
Post Number: 11923
and the overall goal of ur setup??SPL??SQL??SQ??
Post Number: 15
lol im sorry im a total newb and dont know what any of that means. Im basically looking for a sub that would work with that amp to give me good osund quality but when turned up with the gain it will also bump pretty hard, its going on a small extended cab of a truck
Username: Ctmike
Ct.
Post Number: 3686
"turned up with the gain"
gain is not a volume knob.
Username: Nd4spd18
Southeast PA
Post Number: 1064
^^^^^^ X2
Post Number: 16
i understand that, i meant to say when the gain is up itll hit hard when i need it to
Post Number: 11924
ur gain shuld be set to match ur Hu's preout voltage..
Post Number: 17
ok im sorry for the confusion to everyone and on my own part, i meant to say that when need be if i need to turn up the power on either the bass knob or watever than itll hit hard
Username: Big_edge_head
Post Number: 22
dont even use the bass knob. just turn the volume up. it does the same thing. u can clip the amp with bass boost
Username: 420alldaylong
Post Number: 1165
brent watters
Cheap and good you can't beat the price.
http://www.sonicelectronix.com/item_3406_Kicker+05CVR122.html
Post Number: 1166
brent watters
Wire it to a 4ohm.
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=2o hm_dvc&x=136&y=6
Post Number: 19
so if i bridge it it should be fine?
Post Number: 20
joey does that mean id have to bridge it or just one channel?
Post Number: 1179
When you bridge it it will be one channel 450x1 4ohm bridged
Post Number: 21
ok sounds good, ill be sure to pick it up and bridge it, thx joey
Post Number: 11959
whoa..hold on...do u use ebay??
