2 different amps??
Username: Bies08
Wheaton, Kansas
Post Number: 126
ok soo im getting a new set up. im going ot have one W6 that im going to power with an Audiobahn A1300HCT. Then im planning on haveing another sub (you guys woudlnt know what brand it is if i told you anyways) its 300 RMS tho. I plan on powering that with and Alpine MRD-M605. how do i get the power wire and all that to both amps?
Username: Nd4spd18
Southeast PA
Post Number: 1105
Don't mix different types of subs, it will cause cancellation.
Username: Bies08
Wheaton, Kansas
Post Number: 127
cancellation???what?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1609
It'll just sound bad.
-Fishy
Username: Bies08
Wheaton, Kansas
Post Number: 129
Username: Skies
Courtenay, British Colu... Canada
Post Number: 441
The W6 on its own will sound good. Just make sure its in a nice box.
As for power, get a Distribution Block. Knukonceptz makes nice ones.
Username: Bies08
Wheaton, Kansas
Post Number: 130
well how would i do it just in case. after awhile im getting 2 more W6's and im going to power the 2 w6's with the audiobahn then the third one with the alpine.
Username: Bies08
Wheaton, Kansas
Post Number: 132
whats a distribution block do???
Username: Skies
Post Number: 442
Power wire goes from (Battery+) to Distribution block.
It basically effectively splits 1 wire into two. Use ~2Gauge from battery to distribution block, then 4 gauge from distribution block to amps.
