Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 55 Registered: Apr-06 | I am planning on getting a 2000wrms amp and I need to know if it is necessary to upgrade my charging system. Will I need a HO alt. or anything else? I drive a 96 Mercury Sable. |
Bronze Member Username: Mash4kashLafayette, LA Post Number: 69 Registered: Feb-06 | Yes you'll need to upgrade your charging system to a HO alt. for when driving if you want to play when the car is off then you need a deep cycle battery. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1247 Registered: Mar-04 | if you have the 3g 130A ford alt it's very possible it will run ok. The major variable is your listening habits. If it were me - I'd wait. Install it - maybe make some improvements to factory wiring if it looks like it needs it. See what you've got. If you decide a big alt is req'd - then at least you know you need it. |
Gold Member Username: 420alldaylongPost Number: 1162 Registered: Sep-06 | Craig RR Yes you need to upgarde your charging system. Alt/batt http://www.kinetikaudio.com/default.asp http://www.highoutputalternator.com/ How much do you want to spend on a amp? |
Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 57 Registered: Apr-06 | Well it depends..Im willing to spend more if its worth it, but if i can buy a hifonics amp that runs 2000w at 1 ohm and its a good option, Ill go that route. If I need to spend a little more on a better amp I will do that. |
Bronze Member Username: Mash4kashLafayette, LA Post Number: 70 Registered: Feb-06 | go with Rokford Fosate or Kicker I notice u got RR at the end of ur name u into bikes? |
Bronze Member Username: MercsableKalamazoo, MI USA Post Number: 64 Registered: Apr-06 | no, just didnt want it to be just "Craig" so I added it..plus I listen to Rick Ross alot and I wouldnt mind driving a Rolls Royce. The two R's are also on a can of Rockstar and my previous system was two type-Rs. |
