What do you think of mtx 7500 with db 1200.1
Username: Mtx4ever
hi, I just bought an amplifier db drive 1200.1 wich can run 900 rms at 2 ohms, am planing to buy a mtx 7500 12" an run it at 2 ohms, do you think the amplifier is enough for the woofer?, what other woofer would you use for the amp?
thanx for answering
Username: Oglejust
Post Number: 1231
dont know much about the amp but im not a big fan of mtx... u should get a different sub
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 886
^^x2
Username: Dsmith07
NC Http://com4....
Post Number: 621
x3
Username: Dsmith07
NC Http://com4....
Post Number: 622
oh yea whats your budget for a sub?
Username: Freezeman_7
Lindsay, Oklahoma U.S.A
Post Number: 807
thats a great amp. db drive makes good stuff. its prolly a lil under rated, i owned all db drive stuff at one time, it was awesome sq. that amp will push a fi ssd w/ ease!! if im not mistaken i believe its 1 ohm stable as well?
Username: Mtx4ever
I'm planing to spend, between 200 an 250, was also thinkin about a L7
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 1747
Fi.Q FTW
Username: Adam_s
Post Number: 903
SSD with his price range and power.
