Fuse help :-(
Username: Theivan
Dawson Creek, British Colu... Canada
Post Number: 16
hey i keep blowing 60 amp fuses on the power wire going to my amp (500/1 JL) and its only pushing 2 10 inch v2-4's. any ideas on what the problem is/how to fix this???
Username: Carguy
Post Number: 6038
When does the fuses blow? When you turn on the amp or at high volume? What are the voicecoil configuration on the subs? Are they 2ohms DVC or 4ohms DVC? How are they wired?
Username: Theivan
Post Number: 17
i think they're at 4 ohms each and the wiring is bringed (left pos, right neg) and then in the box the left positive goes to both subs and the right neg goes to both subs. so prolly 8ohms if im right? and then the fuse just blows when i have the volume up loud my gain at +8 (goes up to 10). But i know lots of people that dont even blow a 50amp fuse running 1200 watt amps.
Username: Theivan
Post Number: 18
i think they're at 4 ohms each and the wiring is briged (left pos, right neg) and then in the box the left positive goes to both subs and the right neg goes to both subs. so prolly 8ohms if im right? and then the fuse just blows when i have the volume up loud my gain at +8 (goes up to 10). But i know lots of people that dont even blow a 50amp fuse running 1200 watt amps.
Username: Theivan
Post Number: 19
sorry about the double post...could the problem be the fuse is too close to the battery? :S i dont know if that matters or not?
Username: Carguy
Post Number: 6039
Do you have DMM? You will need it to set the gains properly on the JL 500/1 amp as well as checking the ohms on the subs. You can't guess. That amp should operate without problems for 1.5ohms to 4ohms loads.
According to your post, you mentioned +8 gain setting. You can't set gains like that on the amp.
If you go to JL's website, they have a tutorial guide on gain setting for 500/1 amp. Follow it. It's not hard at all.
Once that's set, you amp shouldn't blow any more fuses.
Username: Rwhit59
Granite City, Illinois USA
Help, I have a 1999 Windstar that I replaced the factory radio in last week. During the replacement I blew the fuse to the radio which is also the fuse for the keyless door locks. According to the manual the fuse should be #6. I replaced this fuse but the radio and door locks still will not operate. Is there a hidden fuse that I am missing. Thanks alot.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11720
The 500/1 puts out 500 watts regardless of load, so that is about 42A of current.
If you're blowing 60A fuses, you have a bad amplifier.
Randy, check the other fuses in the fusebox to be sure another isn't blown.
replace them one at a time, or test them with a meter. Don't trust a visual check alone.
Username: Theivan
Post Number: 27
glasswolf sorry about this and maybe im wrong but if you know the formula 500 watts and 8 ohms would be about 62 amps? amps = watts/ohms. right? :P so my amp isnt necessarily screwed then.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11740
no. watts is volts*amps.
you know the voltage is fixed, say 12VDC.
so amps = watts/volts
the impedance is irrelevant with this amp since its got a regulated output stage, and the power out is 500 watts at any load from 1.5 to 4 ohms
Username: Theivan
Post Number: 35
allright. well i blew the voice coils in my subs and so they replaced my amp and gave me some new subs for cheap and hes talkin to his boss cause its their amp that fucked up my subs so they should be free. allrighty then. thanks for the help.
