Is that all!!!
Username: Krazzyboy44
Post Number: 105
The TC-5200 subwoofers are engineered for small sealed, ported, passive or horn loaded box enclosures and designed for high power to ultra high power capabilities. Because of the high BL product, the sealed box volume virtually makes no difference on the frequency response of the system. In other words, there is not a box small enough which would house a TC-5200 to affect the response, therefore it's most efficient to build the box as small as possible. We recommend an amplifier between 1500 and 4000 watts RMS per driver
if dats all the power i wll get a couple
Post Number: 106
somebody
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 1438
What exactly are you asking?If I was in a need for a space saving setup I would go with those subs for sure but that's still quite a bit of power if you ask me.
Post Number: 107
do they really ned 4000 watts or will 1500 be enough
Username: Th3pwn3r
Post Number: 1441
You can under power subs because nothing bad wil happen.Then when you can support/afford more power go ahead and supply it to the subs.The RMS rating on subs is just there so you don't go too crazy and blow em,at the rated wattage the sub will perform it's best is what the manufacturer is telling you.It won't hurt to under power though but it probably won't perform to it's full potential.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 862
Anywhere between 1500 and 4000 should be fine.
Post Number: 108
well with that power do they have tha ability to get louder than tha hd3's
Username: Jkidder
Spring hill, Florida Usa
Post Number: 370
they will sound beter not sure about louder. with same wattage an hd3 would most likely get louder.
Post Number: 109
well is there sub that will get louder than the hd3
Username: Th3pwn3r
Post Number: 1446
It all depends on the install as far as how loud they will be.There's no way to know for sure.
Post Number: 110
well why i hear a lot of people saying the hd3 is louder than a L7
Username: Nyyfan13
Fi SSD USA
Post Number: 4373
hd3 has build quality all day over an L7 and shuold be louder...if you properly power both (hd3 getting 2krms and L7 getting 1krms), hd3 shuold be louder
Post Number: 111
how good is a power acoustik a3000d amplifiers to power a tc-5200
Username: Livin_loud
18 of Love Fi Audio
Post Number: 1429
power acoustic is junk. don't even bother looking at real cheap amps. the cheapest you should buy is hifonics
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 4226
it not will be pretty good
Post Number: 112
a few guys said they will do over 2000 watts
