Replacing factory subwoofer...
Username: Abbrantley
I have a 2001 Chevy Tahoe with a factory 8" subwoofer which performs quite poorly. I was going to spend $600 to replace it with a 10", but then got to thinking. What about just replacing the 8" with a better quality speaker?
What size amp is attached to the factory system?
Anyone had any luck with this?
Username: Oleg
Santa Monica, CA USA
Post Number: 618
I bet it's an amp that has very little power and wouldn't have enough power for much else, but you should find that amp (probably under a seat) and check it out. I can recommend TC sounds TC1000 8" woofer.
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 756
I think those sub's are 8ohm's. Your better of getting a aftermarket sub and amp.
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1516
Power amplifier located behind glove compartment.
Username: Leew
Post Number: 1517
if you wanna add a new amp (without mess)...then you need it:
http://www.pac-audio.com/products/productsCatagory.asp?mmSearch=OEM%20Integratio n
just my thoughts.
