Enough power?
Username: Fsunoles
Post Number: 16
is this amp http://www.crutchfield.com/S-bTYHHcMxIs4/cgi-bin/ProdView.asp?g=120&I=108R611A enough to power this sub http://www.crutchfield.com/S-bTYHHcMxIs4/cgi-bin/ProdView.asp?g=520&tab=essentia l_info&i=500SWR1042#Tab?
Username: Nd4spd18
Southeast PA
Post Number: 804
Yes
Username: Fsunoles
Post Number: 17
decided to change gears and go with with an alpine http://www.bestbuy.com/site/olspage.jsp;jsessionid=LGLIBF45J5X0ZKC4D3JVAHA?skuId =8222345&type=product&productCategoryId=cat03087&id=1166840026929
is that fine
Username: Ctmike
Ct.
Post Number: 3541
yes.
Username: Fsunoles
Post Number: 22
ok rf or alpine for mono amp
Username: James1115
Use a simple...
Post Number: 9564
RF
Username: Fsunoles
Post Number: 24
why?
Username: James1115
Use a simple...
Post Number: 9574
their amps are better then Alpine's amps.
Username: Killswitchjd
Post Number: 292
stay away from new rf
Username: Nd4spd18
Southeast PA
Post Number: 844
^^^^^^ don't listen to that
RF are very good quality amps
Username: Newkid77
Post Number: 9
^^^agreed
Post Number: 302
i think rockford fosgate is overpriced and under performes. there new lines fell off
Username: Nd4spd18
Southeast PA
Post Number: 878
RF power series are some of the strongest amps out there. No they are not cheap but they are very good quality.
