Resonant Engineering 35.1
Username: 420alldaylong
Post Number: 1054
Whats the word about this amp? Thanks
http://ampguts.realmofexcursion.com/Resonant_Engineering_35.1/
Username: Nd4spd18
Southeast PA
Post Number: 939
Well it's RE so it must be good....
Ask Kevin P. he used to have one I think.
Username: Hockeyknight
Post Number: 963
i almost bought 1 off ca.com but the a - hole stopped replying to my pm,s randomly but i did a lot of research on this amp and its really solid. amzing build quality and iv been told that i would see closer to 1800rms with a good charging system
Username: Adddisorder
West palm, Florida
Post Number: 3835
they are great amps same as better audio 1600 i think
Post Number: 1075
Sundown Audio SAZ-1500D
Are they compariable?
Username: Nd4spd18
Southeast PA
Post Number: 956
Both good quality but the Sundown can be run at extremely low ohm loads for burps, don't know about the 35.1
West palm, Florida
Post Number: 3845
sundown can only burp at .5ohm anylower and it goes into protect, plus if you try to use it that low you will also loose the warranty. 35.1 some people run that at .5 and other peoples have blown that low, probly due to lack of current
Username: Ctmike
Ct.
Post Number: 3624
pretty sure the sundown is covered at .5ohm for daily use, as long as it is purchased by the end of this month. after that it's only covered down to 1ohm.
