HELP!!!!!!!!!
Username: Sparky426
Post Number: 14
How do I run the power wire for my amp through the firewall on a 2004 F-150???????
Thanks, Chris
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 56
You should be able to drill a hole threw the rubber part. I've never seen the firewall on a f-150 though. so im just telling you want i've done to my car now and the 1 i used to have.
Username: Carguy
Post Number: 5999
Look carefully at the firewall. There's always some hidden. They will never make a firewall without holes.
Wipe away the dirt. They're usually black rubbery plugs.
Leave the drilling as your last resort cause if not done properly, you could induce rusting.
Username: Sparky426
Post Number: 21
OK, I hooked everything up, and guess what??? IT WORKS!!!! I love the deeper sound and how it fills my truck now, but what a nightmare running wires...
Thanks to all who answered my newbie questions!!!
Chris
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 365
issac wut do u mean leave it at the last resort? if you drill 10 min b4 whats that gonna mater with rust ? or maybe im missunderstanding
Username: Ctmike
Ct.
Post Number: 3585
think he means only drill a hole if there is absolutly no other way to get the wire thru.
