Good deal?
Username: Fsunoles
Post Number: 15
im getting a set of alpine type r 6.5 components for around 130 brand new (best buy) is that the best i can do for the $$. i listen to nothing but indie rock so vocals and mid are a must. im looking to put about 125 rms to them becuase i read that they sound better with more wattage. im in a 2 door so im only going to do the front speakers because i read that the imaging will be better.
Should i just get a 2 channel amp to run the components up front or bridge a 4 channel amp im confused as to what to do, id like to stick to whatever best buy sells due to a discount so infinity, rockford, alpine amps?
Username: Adddisorder
West palm, Florida
Post Number: 3696
i guess you must work at best buy, they dont have much of an online section for amps but look for something that does 100rms+x2 @4ohms and the brands you listed are good for best buy, also eclipse
Username: Fsunoles
Post Number: 21
i got one http://www.bestbuy.com/site/olspage.jsp?skuId=7635865&type=product&productCatego ryId=cat03085&id=1141762608658
West palm, Florida
Post Number: 3707
thats a good amp, same setup i recommended to some other kid that worked at best buy
Username: Fsunoles
Post Number: 23
i mean for that price range 130-200 is there anything better?
West palm, Florida
Post Number: 3723
well ikesound.com has some mb quart qsd's which are very nice, call them to see if they are instock before you order them though.
West palm, Florida
Post Number: 3724
Username: Fsunoles
Post Number: 25
how about cdts
West palm, Florida
Post Number: 3763
higher cdts are very nice like the hd line is supposed to be good and the m6 is supposed to have great midbass
Username: Nd4spd18
Southeast PA
Post Number: 875
CDT HDs will whip the MBQ and Alpine's ar$es
