EVERYBODY READ!!! please
Username: Phuktupbasshead
Phoenix, Arizona United State...
Post Number: 655
If high output alternators did not exist... what setup would you chose?
(consider this a poll or something)
no such thing as a wrong answer, just think about it and be honest.
Username: Matt12490
California USA
Post Number: 1802
I don't think I would exceed 1000 watts so a nice 1000 watt amp powering:
-15" DD 1500 series
-15" Fi Q
-15" Avalanche
-15" Eclipse Ti
-2 12" w6
Sorry couldn't choose 1. Money would be a factor so the dub 6s are out. If it wasn't they would be my choice.
Username: Matt12490
California USA
Post Number: 1803
Wait, do they even have a 15" 1500?
Username: Arande2
Extreme SQ FTW
Post Number: 1715
I like the Q.
Username: Johnfiac
IL Afghanistan,...
Post Number: 1627
Id just have a decent sized big bank of batterys and about 3Krms
Username: Johnfiac
IL Afghanistan,...
Post Number: 1628
Dont have to push 3Krms all the time tho... just when 1Krms isnt enough.... never really is tho.. haha
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 1167
Well I would definately run a JL 1000/1 and power some W6's with it :-)
Username: Stnorris
RE SX 15, IA US
Post Number: 2074
2 re sx 15, a few batteries in the back, and 2500rms. ..i think that any more power would be hard
Username: Matt12490
California USA
Post Number: 1804
2500 and 3000rms is way too much power for a stock alt. Extra batteries aren't going to help at all if your alt can't charge them. I thought you guys have been here long enough to know this.
Username: Nd4spd18
Southeast PA
Post Number: 606
x100
I was about to say exactly that
Username: Oglejust
You aint bangin unless..., Il
Post Number: 1135
if ur not running the subs up all the time the alt will charge them.
Username: Matt12490
California USA
Post Number: 1816
never bumped
Username: Blazerboy
Post Number: 350
My situation exactly!
I choose 1 15" ssd, and give it about 800-100watts.
Username: Andrew571
Post Number: 699
buy multiple stock alts and run 2k+!!!!!!!
Username: Johnfiac
IL Afghanistan,...
Post Number: 1644
"Dont have to push 3Krms all the time tho... just when 1Krms isnt enough.... never really is tho.. haha"
Sh!t i'd run 10Krms on a stock alt. THe only thing im saying about that though is i wouldnt be holding a constant 3Krms just kinda like turn it up when the good songs come... or to scare some chick in the backseat.. ;) 3minutes of strong bass.... then a good 30minutes of charging lol... but thats me
Username: Nd4spd18
Southeast PA
Post Number: 633
" buy multiple stock alts and run 2k+!!!!!!! "
Now there's and idea!
" Sh!t i'd run 10Krms on a stock alt "
You would be replacing that stock alt quite often.
Username: Johnfiac
IL Afghanistan,...
Post Number: 1652
yes i would....BUT
Bass > alternator :-)
Ill keep extras in the trunk at all times if i had to... its only a 2-5minute job to swap it out
Username: Rustysurfer916
Oviedo, FL
Post Number: 360
same system im gonna be running. 1000 watts on 2 W6's
Post Number: 656
no, seriously...
without high output alternators, and without additional alternators...
What would you guys do? That being your limitation... what would you recommend or install in your own vehicle/vehicles?
Username: Mygame5982
Memphis HPO 15 Wangers..., TEXAS US
Post Number: 1302
fosgate t1001bd
planet audio vx1400d
memphis prd1000.1
iono a pair of woofers to match
Username: Renegadesrun
Lafayette, IN US
Post Number: 572
For you? A small 2-300w set up. Brands irrelevent.
For the rest? Save your money, take your ignorant butt back to school and pick up where you left off.....5th grade math.
3/4 of you need to get run over by the clue train. I would think it impossible to post with your head in your a55 but apparently not.
The numbers mentioned to be run off stock, are absurd, and the idea that the stock alt will charge some magical storage device (battery?...if so...LOL) that will allow you the use of "said storage" for longer than a millisecond is moronic.
Lafayette, IN US
Post Number: 573
We obviously have differing opions on what you guy consider as "will work".
3/4 of the people here probably never realize even 1/2 of their amps potential for lack of proper charging. Does it play? Yes. That doesnt make it right tho......
I dont consider a stock alt with much more load on it than what was supplied by the manufactorer. Large cases are a small exception, but not much of one.
Username: Carguy
Post Number: 5991
On a stock alternator, JL 500/1 and 10W7 in a HO box.
For those trying to run 3K - 5K of power, don't forget, with electronics, all it takes is micro seconds to burn out. Unlike human body, once damaged, it does not heal by itself. 3 mins of full blast may not sound much to you, but to a car's electrical system, that could enough to fry everything..
Lafayette, IN US
Post Number: 574
Sup fellas....noone got fired up? Havent pi55ed in the ecoustic wheaties lately, this seemed like a likely spot.
Heh.
Anyway...when a stock alt averages 90-120amp, which barely covered all the cars functions at once....and you add an amp who's draws SURPASSES, what you have to give by over 100% (1000w amp, or more), you can begin to see where im coming from sans the bluster, name calling, and BS. ;)
Username: Adddisorder
West palm, Florida
Post Number: 3543
haha thanks regegadesrun for clearing that up, i somehow missed this thread but people dont belive me when i say 600rms killed my 80a stock alt.
Username: Liqdfire3
Lee high acres, Florida
Post Number: 124
how hard is it to run multiple stock alternators? and is it more cost efficient than buying a high output one?
Username: Nd4spd18
Southeast PA
Post Number: 663
^^^^^ No.
Custom brackets for multiple alternators are expensive, if you can even fit a second alt on your engine.
HO alternator is the way to go.
Username: Dj_007
Carlisle, KY US
Post Number: 62
i would run a 1000 watt memphis audio reference series amp on 2 15'' M3s..
Username: Southernrebel
Post Number: 4522
If high-output alts didnt exist...i would invent them and make some $ :-)
FI Audio BTL 15Los Angeles, CA
Post Number: 10744
i'd just keep it stock. i am already thinking about stock system now. damn bass is just too much work and you are never satisfied.
Username: Tremor1127
Fi Car Audio [:-]
Post Number: 1057
shoot, im satisfied... :-)
Post Number: 658
Rearrange, Andre, M.S., Matt, James, & Derek: thanks for your suggestions... I appreciate your opinions.
Killa: I wish I had the money and ability to abuse car parts the way you mentioned! Seriously, if I could afford to throw away alternators... I could afford to avoid all that by buying a high output one for sure. lol At any rate, thanks for sharing.
Liqdfire3: That was a GREAT question! Even if it seemed like a new-b question to some... I felt it was totally valid and am glad that you asked.
Chad: I know what you mean about the satisfaction part... yet, I still want to pursue it until I get tired of it myself. (i'm sure you understand) What do you recommend for getting the most out of the stock alternators? (since you're currently working on that type of setup for yourself) I really value your expertise... please respond again.
renegadesrun:
Obviously you know what you're talking about (or are so good at bull$hit that you believe your own lies - lol) Seriously, you do seem to have a greater knowledge than I do... so please go on... nobody is offended... it's all good.
How come you only recommended 200-300 watts? Is it THAT delicate of a situation? I'm currently running a Digital Audio DAD9004 at 0.8 ohm in a 1990 Dodge Ram Van (2 12's and 1 10)... you think my alternator will go??? My $hit pounds harder than ANYBODY in my neighborhood... despite that, I'm still not totally satisfied. Honestly, without talking down on me, bro - what should I do? Try to upgrade more with the current alternator with more subs and better boxes? Or just get the high output alternator and start from scratch once it's ready to go? If that is the case: which alternators do you recommend? Remember, I'm pretty much looking for the cheapest one that isn't JUNK - brand name means nothing to me regarding alternators... I just want to know which is the cheapest alternator that'll do the job? Please respond. I appreciate and value your expertise.
As for everyone else:
The question still stands... if there were no high output alternators, what would you have in your ride to make it PUNISH the block? Recommendations, suggestions, advise.
Thanks for reading, everyone... please respond.
West palm, Florida
Post Number: 3593
for a cheap stock amp set up get a pg x400.1 and a crossfire amp that does like 75x2 and your alt should be ok with it seeing as music is dynamic and chances are your amps will never be pushed to their limits unless you abuse the volume knob
most stock alts are great if you dont have alot of draw, ho alts tend to run hot and that can shorten the life. really running two stock alts that say total 200 would be better then getting a 200a HO but only on some cars can you fit the extra alt. a good place to gets your rebuilt to HO may be a local alt. comapny, you should call around.
Post Number: 659
thanks, Mat Dope... I will.
Anybody else?
Username: Logan__tille
Imortal Box Building, Email us wit...
Post Number: 6334
Orion 2500D and 1 15" FI BL.
Post Number: 662
ALSO, check out the thread titled"so, who thinks high output alternators..."
