New member Username: GdsndcsPost Number: 1 Registered: Mar-07 | i have 2 Pioneer premier 126dvc's(400 rms) right now. I am purchasing a CV vmax 12.2(600 rms). Premiers are powered by power akoustik(dont have yet) 1440, which has 720 rms...so 360 to each sub at 4 ohms. the vmax will be powered by a kenwood 8101d 500 Watt rms Mono which i already have.(at 2 ohms) NOW the question. What would be my best setup in terms of boxes. I have always liked bandpass but i know that they are considered crap. I am looking for more spl than sq. So should i box them together or seperately. as of right now i am planning on getting http://item.express.ebay.com/BC-312-TRIPLE-12-BANDPASS-SUBWOOFER-BOX-ENCLOSURE-N EW_W0QQitemZ270096517394QQptdnZQQddnZQQadnZQQcmdZExpressItemQQtabnavZ1#tabs so what do ya'll think. I am up to changing amp/sub within a right price |
Gold Member Username: Logan__tilleImortal Box Building, Email us wit... Post Number: 6350 Registered: Feb-06 | I have a box the would be perfect fo you. ![]() |
New member Username: GdsndcsPost Number: 2 Registered: Mar-07 | Would that be for the 2 premiers? i have 3 12s to work with and with the triple bandpass i was going to put the vmax in the middle. But otherwise i like that box, whats the ft^3 per sub? |
Gold Member Username: Logan__tilleImortal Box Building, Email us wit... Post Number: 6352 Registered: Feb-06 | 2 cuft per sub. dont use a bandpass, and dont mix and match subs like that..not good. |
New member Username: GdsndcsPost Number: 3 Registered: Mar-07 | so i decided to go with this... Getting another Pioneer sub so 3 Pioneer premier 1000/400 watts and the amps are going to be: Power Acoustik 1440 going to 2 of them giving each 360 rms at 2 ohms Power acoustik 620 2 Channel bridged to give 360 rms to rhe third at 2 ohms. All in either a triple ported or triple bandpass So what do you think about that, not the loudest but should hit pretty good? |
Gold Member Username: Logan__tilleImortal Box Building, Email us wit... Post Number: 6358 Registered: Feb-06 | No..get a better amp. |
New member Username: GdsndcsPost Number: 4 Registered: Mar-07 | what do you recommend to power all three?within a reasonable price. Cause what i have gets them all 360 rms and 720 max. The subs themselves are 400 rms and 1000 max. |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 1666 Registered: Feb-06 | How much do you have to work with? You need about 1200 watts so look on ebay for a used orion 1200d or a vr1000d or your cheapest option would be a hifonics bxi1500. you oculd also look into a kicker 1200.1 or kicker 1000.1 make sure you look at the vc configuration of your subs so you can get the desired wattage from your amp. |
