CVR vs
Username: Mmaudioconcepts
Murray, KY
Post Number: 51
what is better than the kicker comp vr 10 in the price range($50-$150).looking for sql i know of a few but im sure i dont know all. so i just need opinions
Username: Oleg
Santa Monica, CA USA
Post Number: 456
CVR is a good sub, I think alpine type R is in the price range. I just got some TC sounds tc-1000s, pretty good price. Another good choice is adire audio shiva.
Murray, KY
Post Number: 52
my bad for the posting in the wrong section
Murray, KY
Post Number: 53
how good is that tc sounds and howm uch power do you give them
Username: Oleg
Post Number: 463
I haven't put them in yet. I have a 2400W RMS amp, so probably wire it at 4ohms and give them 300W rms. Or I may wire them at 1ohm and give 1200W each, but turn the sub-out all the way down. I think 400W rms would be fine for them, as recommended. My friend does have the 12" comp VR's and they're like $75 shipped on eBay...hard to beat for that price. They don't need a lot of power...300W RMS each and I recommend you get a custom built ported enclosure for it(them), if you do get it. I'll be able to tell you how the TC sounds subs are in about 2-3 weeks.
Murray, KY
Post Number: 55
i really didnt want the kicker, thats why i was asking what is comparable
Username: Oleg
Post Number: 469
Adire shiva is a good sub. I only heard good things about the TC subs, that's why I got them. I suppose I'd recommend tc-1000s to you as well.
Murray, KY
Post Number: 56
where can u get the shivas from
Username: Oleg
Post Number: 471
Right here...
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/shiva_class ic/
I think shiva is a dual 8ohm sub.
Username: 420alldaylong
Post Number: 963
http://www.audioque.com/aq/SD2_Series.htm
Murray, KY
Post Number: 62
I have narrowed it down to
4 DD 1510
4 Audioque SD210
4 Diamond D310
4 Memphis pr104
2 Diamond D610
2 Memphis M310
Murray, KY
Post Number: 63
what would you do
Username: Oleg
Post Number: 477
What type of sound scheme are you trying to accomplish? I see you want to get really loud, but how about sound quality? What kind of power do you have available?
Murray, KY
Post Number: 64
i am making a demo car..so that customers can get an idea of some of the things that can be done...i will supply them with whatever power i will need....sound quality is an issue....so id say an
sql setup
Username: Ctmike
Ct.
Post Number: 3479
dd.
Username: Oleg
Post Number: 478
4 subs will get sloppy, but loud. Can you do 2 or 3 DDs instead?
Username: Adddisorder
West palm, Florida
Post Number: 3533
oleg how will 4 subs get sloppy?
and MnM you missed out man i just sold assassin 12 thats perfect low power sql
Username: Oleg
Post Number: 485
It's a lot of air to be moved to maintain high SQ. There was a thread about that earlier and that's my opinion as well.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4227
DD FTMFW!
Murray, KY
Post Number: 67
so 4 subs gets sloppy...i know a guy who has 16 JL10w1s in his seabring..
Username: Nd4spd18
Southeast PA
Post Number: 651
" 4 subs will get sloppy "
BS flag on that one. SQ is about the frequency response and overall sound of the sub and enclosure. Doesn't matter how many subs there are.
Murray, KY
Post Number: 68
point made,so my list is narrowed to
4 DD 1510
4 Audioque SD210
4 Diamond D310
4 Memphis pr104
Username: Oleg
Post Number: 495
haha BS flag it all you want. I've heard 4 subs before and then just 2 of them. 4 was incredibly loud, but it lost a bit of clarity in the process. 2 wasn't as loud, but maintained most of the musicality and clarity. I doubt you can tell me my ears are wrong, but you can voice your opinion without hating on mine.
Murray, KY
Post Number: 69
so it lost a bit of clarity,,,,,how much is a bit,,,and how clear can trunk bass be
Username: Oleg
Post Number: 499
At high volume, the bass notes pretty much all blended together without much definition with each specific frequency. With 2, the difference between notes was much clearer. So I'm saying, MY PERSNOAL CHOICE would be to stick with 2 subs if I was looking for purely SQ.
Murray, KY
Post Number: 70
basically i want it to sound good at medium volume...at high volumes its ok if it loses a little clarity
Username: Basssquared
Post Number: 232
but hes not looking for "Purely SQ" hes looking for SQL big difference
Username: Juliob
Post Number: 4237
2 DD 3512 and that's it. I'd rather buy 4 10s. Forget about oleg.
