Bronze Member Username: Chris_t54Post Number: 56 Registered: Dec-06 | I have about around $450 to spend on a set of subs im thinking 12's should be fine, i have a stock alt around 105 amp or so and a large trunk and some heavy duty kicker pdk1 amp kit wiring i need to know what to get tell me the subs and then match it perfect with an amp and give me the sites/info about it thanks!! Also im looking for more SPL then SQ got a friend who has some 12' CVRs and i wanna blow him out of the water haha |
Silver Member Username: 420alldaylongPost Number: 981 Registered: Sep-06 | Subs http://www.audioque.com/aq/SD2_5_Series.htm Amp VR1000D http://www.crossfirecaraudio.com/frameset.asp |
Gold Member Username: RvlacosDD 3512 , VR1000D 15= overcomp... Post Number: 1860 Registered: Sep-06 | good recomendation joey! that amp is way under rated! great build quality 2! what vehicle do you have? how much space is available? i have out hit a few guys with 2 15" cvrs with 1 12" when you do that it makes you feel better and them feel worse 1 12" out hittin 2 15" ftmfw! <~~~~~~ 15" = overcompensatin |
Bronze Member Username: Chris_t54Post Number: 57 Registered: Dec-06 | I have a 97 monte carlo im not sure exactly how much space but a lot |
Bronze Member Username: Chris_t54Post Number: 58 Registered: Dec-06 | how much are those subs and then an amp because they don't really tell a price |
Bronze Member Username: Chris_t54Post Number: 59 Registered: Dec-06 | come on guys take 2 secs out of your time and help a brotha out! |
Platinum Member Username: BestmankindKINETIKLos Angeles, CA Post Number: 10893 Registered: Oct-05 | richard 15" = deeper bass. lol. |
Gold Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 1259 Registered: Jul-06 | I would wait for Ascendant Audio's new line of woofers to come out ![]() |
Gold Member Username: JohnfiacIL Afghanistan,... Post Number: 1699 Registered: Mar-06 | 2 9515's > 1 3512 ![]() |
Gold Member Username: Denali_on_22sHit you in the chest m... Post Number: 1622 Registered: Feb-06 | they are like 149 a sub i think maybe less email them and see |
Silver Member Username: Kyle_lowePost Number: 200 Registered: Apr-06 | yo chris, i have that same car so i would like to point out some problems you might run into if you want to hve your subs pushed back into the trunk then the widest outside diamiter of your box can only be 32" but also if you take a look it gets slightly less wide the fartherback you go. also the max height it can be is 16 inches. just thought i would give you some info on the car in case you have not yet taken a look for yourself. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 4073 Registered: Jul-06 | on audioque.com...go to the sub drop down and click order form...yhoull see prices |
