Best subs for under 700.
Username: Scaraudio
Irmo, South Carolina United States
I would prefer two 15s. I'm building a huge custom box for my ext. cab Ranger. I was thinking maybe two type r's or maybe maybe two kicker s15l7s. Also any insightful information on picking out a amp or two would be greatly appreciated.
Username: Loudon
Post Number: 857
i would do ...
2 15inch ssds
id seal em up .. about 4 cu/ft
Username: The_image_dynamic
San Diego
Post Number: 446
Yeah or some Q's would fit his budget too. I agree on the sealed for a Ranger unless this guy wants a full-on ground pounder.
http://www.ficaraudio.com
Username: Loudon
Post Number: 858
i doubt hes competing with it ...
he didnt state ne electrical upgrades ...
Username: Jkidder
Spring hill, Florida Usa
Post Number: 322
2 15" DD Audio 2515's with an ed.nine
Username: Scaraudio
THANKS for the quick replies! Ya, I'm not competing with it... currently. I would love to get into it thought. I'm gonna go check out all these suggestions. Thanks again, Trey
Username: Scaraudio
O and btw, I am going to port the box. I have built a few boxes and going to really try to make this one high quality and unquie. The ext cab will be perfect for a system once I remove the jump seats. What electrical upgrades would I need to get setup for a competition system. Alternator, extra battery?
San Diego
Post Number: 453
Hold on there cowboy....we could use some more info. Like:
What year Ranger is it?
What do you want out of this system?
Quality? high output? A little of both?
Do you want to be able to rip your girlfriends hair out, or do you just need some killer low end for daily tunes?
How much is your budget for the amp?
Username: Scaraudio
2000 Ford Ranger 4x4 Ext. Cab (takin out jump seats tommarow.) Both, and yes I wanna rip dat hair out! Pretty high budget for amp, whatcha thinkin?
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 1568
You need 100 amps for every 1000 watts (basically) plus room for your regular electrics in your car to run. Say you want to go with 2500 watts, you should probably get a 300 amp alt, and that would provide more than enough power and you wouldn't have to buy a buncha of expensive batts. That being said, the alternator will probably run you 400-500 dollars. You also need a Big three upgrade with 0 guage wire.
You can get a nice amp cheap depending on how much power you are running. I would say you could have ridiculous bass off of 2000 watts. 2500 if you deem it necessary. Go with a couple of DD3515s if you have 6.5-7 cubes to work with (which I'm not sure you have)... if not, go with a couple of 12s.
San Diego
Post Number: 456
Reece is right because you're going to want around 1000 watts to each 15". In a Ranger, you would be much better off going with one 15 ported for what you seem to want. You have to realize that these woofers are very high output and one of them in a good ported box will kick some serious azz in that small space. And you would save alot of cash of you can avoid going over what your stock alt can handle.
I would put a dual 2 ohm Q15 in a ported box
with one of the following amps:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2617
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3964
There are amps for sale all the time here and a couple guys building boxes in this section so keep an eye out.
San Diego
Post Number: 457
Nah scrap that Kicker, it's not 1 ohm stable but you get the idea.
Username: Southernrebel
Post Number: 4519
Gene,
I have done a few installs in ext cab rangers...w/ the room you have, i would go w/ a pair of nice 12's .
You could do ~5cuft net and stay under the window-line pretty easily and you will be able to lean your seats back....you can get 7.5cuft, but the box will be a b1tch to build if you want to lean your seats back any at all.
If you want to run ~2000wrms, look into these subs:
Fi SSD12
Fi Q12
DD2512
DD3512
AQ HD312
Username: Scaraudio
Thanks for all the help. I'm goin with a single 15" in a bad azz box. I've built a few of them in the past and will try to build this one so i have about 4-5cuft and still be able to lean my seat back. I'll also take pictures and put them up so yall could see my work. Thanks again, Trey
Post Number: 1582
What 15 are you going with and what amp?
