Dual voice coil or bridge hookup or wat?
Username: Ceoofdaroc4
Post Number: 24
Hey whats up I'm getting two 10 inch L7s and I have a box at my crib which my friend is going to put my subs in but he doesn't kno how to hook it up inside wether to do dual voice coil or bridge it or what... what should I tell him 2 do I'm having an audiobhaun A8000T 800 watts running 2 each sub.. So how should he wire thm?
Username: James1115
Use a simple...
Post Number: 9299
what is the configuration of the voice coils? dual 4 ohm or dual 2 ohm?
Username: Imalik
Jackson, New Jersey Ocean
Post Number: 118
This will help you out
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
