How to hook up ure amp to see if it is blown
Username: Mike_16
Burlington, Wisconsin Us
Post Number: 239
sry about tht last thread it got fu..ed up but how can i hook my amp up to se if it is blown besides hooking it up to the wireing? there has to be an easier way thanxx
Username: Logan__tille
Imortal Box Building
Post Number: 6195
connect it to a battery
Username: Wazz
Post Number: 17
one of my questions is if the protection lights is ON what does this means how can i fixe it my amp its not working no mre since the protection lihgt came out...any help?
Username: Livingloudl7
Post Number: 28
"Protect" Well its kinda self explainatory. Your amplifier is trying to protect itself from exterior or possibly interior problems. Could be your wiring or I believe your subs can actually cause this too.. check over your wiring, and just kinda hope its nothing inside your amp cause thats no fun.
Username: Van_man
Boston South, MA
Post Number: 2087
<object><param></param><embed></embed></object>
Username: Van_man
Boston South, MA
Post Number: 2089
disconnect your subs...does light go out. Check your ground. check your rem and power wire. batttery? Alternator?
Username: Mike_16
Post Number: 240
ok i was in florida and, so just open my hood and conect the battery wire is that it?
Username: Mike_16
Post Number: 241
woops, i meant i am back from florida and home now . but anyways how would i do it? just conect the power wire and thats it?
