How warm is too warm?
Username: Trey4sports
Post Number: 553
i just got done listening to my subs and i was wondering if its normal for the dustcap to get warm, not hot, but warm the cone nor the surround is warm so i was wondering what signs should i look for to see if the sub has reached full potential, i know what it sounds like but i was wandering what the aftermath should look like? and if the coil is starting to smell is that an indicator?
Username: Stnorris
RE SX 15, IA US
Post Number: 2079
whats ur box tuned to and do u have a subsonic filter on?
Post Number: 554
about 37 hz and yes the subsonic filter is on
Post Number: 556
i think i was feeding each sub about 800 or 900 RMS for 10 second intervals because my alt cant handle that much power
Username: Yukhui
Myrtle Beach, South Carolina USA
Post Number: 437
What sub and amp do you have?
Post Number: 557
2 WMD 15's and a massive audio P3000.1 but i have the gain on the P3000.1 at about half, paired up with a 5V preout HU
Username: Drivingreckless
DD 9515f, USA
Post Number: 3031
you dont want to smell your VC
leave it at that....
if you do smell it turn it off and let your subs cool.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 758
On my rl-p the cone used to get warm after I would play it hard for a long time. It never smelled just got warm.
Username: Matt12490
California USA
Post Number: 1815
Are you saying your gain is set to 5 volts?
Post Number: 560
no i was just saying my head unit is 5V
Post Number: 561
but heres the thing, after a while i can smell the VC but yet there is not distortion ?
Username: Frkkevin
Post Number: 3254
if the subs are new and you smell the coiils its normal...
Username: Oneracistguy
TWO EGG, FL USA
Post Number: 343
to a certain point^^^
Post Number: 562
its not a strong smell at all only when i get to the box i can slightly smell a rubber type smell
Username: Adam_s
Post Number: 761
That is prolly the excess glue. How new are the subs??
Post Number: 563
uhm install was done saturday night so 3 days maybe 2 hrs of listening total
Username: Bernymac
Cambodian
Post Number: 2120
that amp is badazz huh :D
Username: Adam_s
Post Number: 765
Yeah. I would almost 100% its the glue if you say it only smells by the box and smells like rubber.
Post Number: 573
yeah i saw on the ROE 12" challenge the WMD has lots of excess glue, and is it normal for the dustcap to be a little warm?
