New member Username: FsunolesPost Number: 6 Registered: Jan-07 | i want to run a set of type r 6.5's and a type r 10. for the components i want to run about 110 rms to the components up front and about 400-500 rms to the 10 considering on my car i have a metal plate between the backseat and trunk. what kind of amp should i run, id like to stick with alpine but im stuck. do i need two amps? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3414 Registered: Jan-06 | today is your lucky day. iv got a pair of alpine type R 6.5 comps and an amp thats perfect for them directed viper 400.2 125x2@4 250shipped for it all. and for a sub amp pheonix gold xenon 400.1 off of ebay |
New member Username: FsunolesPost Number: 7 Registered: Jan-07 | thanks but i get a discount and i want the 07 pair |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3425 Registered: Jan-06 | hehe lucky you then, memphis also makes an amp thats like 500rms |
New member Username: FsunolesPost Number: 8 Registered: Jan-07 | i have a kenwood around from my other system is this enough to power the type r components ? http://www.cardomain.com/item/KENKAC8401 |
Gold Member Username: Logan__tilleImortal Box Building Post Number: 6198 Registered: Feb-06 | yea, it will be ok |
New member Username: FsunolesPost Number: 9 Registered: Jan-07 | and how about this for the 10 http://www.bestbuy.com/site/olspage.jsp?skuId=7730093&type=product&productCatego ryId=cat03087&id=1140392383944 thats 456rms at 4 ohms continuous that would be enough power |
New member Username: FsunolesPost Number: 10 Registered: Jan-07 | how are kenwoods, i mean i have it already so there is no point in buying another if that has more than enough power to push the set |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3442 Registered: Jan-06 | i powered those speakers with 75rms and thought they sounded weak, put 125 on them and they came to life. like i said im selling that amp for 125 shipped so... i guess try it with the kenwood and if you dont like it get something better |
Silver Member Username: Nd4spd18Post Number: 506 Registered: Jul-06 | Kenwood amps are not good. If you already have one you can use it, just don't be suprised if it breaks. If you're looking to buy an amp, get something better. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4204 Registered: Dec-05 | i'd prefer profile for low budget amp. |
Bronze Member Username: FsunolesPost Number: 12 Registered: Jan-07 | ok im going to use the kenwood, what should i use to power the 10 im looking at putting about 400-500 rms |
Silver Member Username: Nd4spd18Post Number: 523 Registered: Jul-06 | What VC config is your sub, and how much are you looking to spend? I have an amp that does 400 watts at 2 ohms that I would sell for $75 if you're interested. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4210 Registered: Dec-05 | jl 500.1 or PM mat dope for his PG. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3454 Registered: Jan-06 | actually julio that x400.1 is sold to wolfman but jason should pick one up on ebay |
Silver Member Username: Nd4spd18Post Number: 526 Registered: Jul-06 | or buy my amp |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 4213 Registered: Dec-05 | finally you sold that amp! |
Bronze Member Username: FsunolesPost Number: 13 Registered: Jan-07 | dual 4 ohm coils |
Silver Member Username: Nd4spd18Southeast PA Post Number: 576 Registered: Jul-06 | I have a 400 watt amp that will work with your sub that I will sell for $75. If you're interested email me at: nd4spd18 AT gmail DOT com |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3469 Registered: Jan-06 | yeah juilo wolfman is definatly going to buy it |
Gold Member Username: Matt12490California USA Post Number: 1793 Registered: May-05 | Is that viper amp refurbished? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3474 Registered: Jan-06 | no, i bought it new on ebay. it works fine im just buying more power and changing amps for an active set up, if your interested pm me and ill send you some pics |
