Jensen UV7i
Username: Gafielicous0690
hey, I've noticed that there has not been a lot of talk about this model, but does anyone out there know how to disable the emergency break sequence on this model by using the remote only? I have no idea how to do wiring, and I don't want to have to pay anyone, so if there is a remote control sequence that someone knows, please let me know.
Username: Lowrange85
Here is the code:
I did this with the remote
Press stop twice(which is also the BAND button)
Press 1,2,6,4
Press down 1 time(button below the Play/Enter)
Press Play/Enter 1 time
(You should now see the menu)
Brake override should say No
I was told to change macrovision to No
Hit sys setup twice to save and exit
Hope it works like mine did!
Username: Klive
Wilmington, Nc Usa
hey i just bought the uv7i model and after the guy hooked it up he told me it was a code to overide the parking brake can you help me
Username: Dayone84
Woodstock, Ga. USA
I just Installed The Phase Linear Uv7I. When it powers on Does The Screen Stay Blue, even when the Radio Is On or When you put a cd in. Is it Because I don't have the e brake hooked up yet. i'm going to install the switch soon. I just wanted see if the screen was going to stay blue until hook up the switch.
