2 Amps 2 Subs Need Help
Username: Deathskrye
Ill be using the following:
2 Alpine Type R's DVC 4 Ohm
2 Rockford Fosgate P550.2 4 Ohms Bridged: 550 watts RMS x 1 chan
1 Pioneer DEH-P3800MP
Im going to have both the amps amps bridged one onto each sub. Powerering each sub at 550 watts each.
I will be using a cap
So how do i wire it, like the battery, ground, i really dont have much of an idea.
Ive only installed 1 Amp 1 Sub before
Any help would be really appreciated
Username: Oleg
Santa Monica, CA USA
Post Number: 403
You can run 1 power wire to your cap, then connect the cap to a distribution block, which you'll then connect to your amps.
