Silver Member Username: PitbullguyChicago, Illinois I Eats Beats... Post Number: 874 Registered: Oct-06 | I get my choice of fuse size with this amp kit...what size should i choose? It's gonna be used with an Elemental Designs nine.1 amp at 1ohm powering 2 12" arsenals. http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0 also gonna get this distribution block if it's relevant... http://www.knukonceptz.com/productDetail.cfm?prodID=BC-1024 |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1208 Registered: Mar-04 | 150A would cover the nine.1, but what's the d-block for? running a 2nd amp? |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3395 Registered: Jan-06 | id just get the 250a incase you decide to ever add another amp or whatever you be in the clear. you could get away with a 150a if you wanted. and instead of getting that D block you could always cut off some of the wire at the end to make it skinnier so the 1/0 will fit in the 4g amp terminal if you want. |
Gold Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 1116 Registered: Jul-06 | Dude you think the 250 amp fuse will pop before that amp does?Lol, I'm not that familiar with that amp but I think if it saw more than a 250 amp current that it would smoke. |
Gold Member Username: Matt12490California USA Post Number: 1759 Registered: May-05 | The amp has its own fuses to protect it. |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3399 Registered: Jan-06 | exactly |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1213 Registered: Mar-04 | I suggested 150A only because that's more than enough for the nine.1 and will just a higher factor of safety vs 250. That's why I asked about a 2nd amp because the 150A should be adjusted for it if it's sizeable at all. But yeah, the 250A will work too. And not to pile on, but Rob, the fuse at the batt is for wire protection only. Fuses on or near the amp are the only fuses intended for amp protection. In my personal experience, however, the only time I've blown an on board fuse the amp was already toast. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1214 Registered: Mar-04 | edit: "will just offer a higher factor of safety..." |
Silver Member Username: PitbullguyChicago, Illinois I Eats Beats... Post Number: 877 Registered: Oct-06 | hmmm so i don't need the distrib block then i guess. I was under the impression i needed it because the 1/0 wouldn't fit but if you say i can make it fit then i'll pass on the block |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 1074 Registered: Mar-06 | does a nine.1 accept 0? Dont think so and my computer is too slow to go look anywhere |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 3406 Registered: Jan-06 | yeah you can make the wire fit you just have the cut off the extra outside layer after you strip the end. |
