Is 1 ohm or 4 ohm louder at the same wattage
Username: Georgiaboy1989
Kennesaw, Georgia
Post Number: 38
is 1 ohm or 4 ohm louder at the same wattage
Username: Freezeman_7
EveryThing I Own is FO..., OK U.S.A
Post Number: 720
welll your question is kinda general cause, if you put the exact same watts at 1 ohm and then at 4 ohms, yeah the 1 ohm will be waay louder, cause of less impedence. but if you wanted to push 500watts at 1 ohm, and with that same amp, it would prolly be 200watts at 4 ohms, but if you wants to push 500watts at 4 ohms with a different amp, taht same amp if 1 ohm stable would put out about 800watts, its really complicated sometimes, but not after you get the hang out it, hope that clears it up for you... what are you looking to push and with what amp?? that woujld help me out alot...
Username: Nickb4247
Post Number: 236
A watt is a watt. 400@4ohms is the same as 400@1ohm.
Username: Nickb4247
Post Number: 237
The difference is the effect on the cars electrical system.
Username: Adddisorder
West palm, Florida
Post Number: 3365
nick what you just said doesnt make sense. if 400@4ohms is the same as 400@1ohm, then how would that be different on the cars electrical system? It wouldnt because its the exact same amount of power and its going to have the same amperage draw as long as both amps are the same efficacy.
Post Number: 721
so does anyone agree with me>??? cause it was kinda hard to explain
Username: Aaronjp1990
Lerwick, Shetland Uk
Post Number: 34
i think what he want to know if you ran the sub with a 400@4 ohms and different amp that puts out 400@1 ohm. and if there is any difference.
Post Number: 722
oh well, then only thing would be the amps cooling system, but no the way aaron put it, its not a big difference, your amp will run cooler at 4 ohms tho.. 1 ohm is an un stable load on alot of amplifiers
Post Number: 35
so you want to run at 4ohm rather than 2 or 1? higher the ohm the better?
Post Number: 723
Username: Nickb4247
Post Number: 238
It is more efficient to run an amp at lower impendences
Post Number: 36
i h8 all this ohm stuff :-( am going to run a jl 500/1 amp on a 13w6v2 sub at 2ohms.
Username: Kaimana
Post Number: 8
doesn't it put more stress on the electrical system when the ohms are lower??? i always thought that it was easier for an amp to work at a higher impedance....
West palm, Florida
Post Number: 3366
untrue kaimana. it all depends on how much power your putting out. on many amps the lower ohm load the more power but if your talking different ohm load same power then it doesnt matter.
and chase not to sure on anything you said...so ill leave it at that
Username: Kaimana
Post Number: 9
^^aight so its only more work on the amp because generally it would put out more watts at a lower impedance.....
Post Number: 727
yeah i think i made it more confusing.... my bad. if mat cant understand i doubt anyone else can... lol
Username: N2audio
Lawrence, Ks USA
Post Number: 1202
"if you put the exact same watts at 1 ohm and then at 4 ohms, yeah the 1 ohm will be waay louder, cause of less impedence."
Disagree. Power is the only factor of an amp that has any effect on SPL.
"A watt is a watt. 400@4ohms is the same as 400@1ohm."
yes
"nick what you just said doesnt make sense. if 400@4ohms is the same as 400@1ohm, then how would that be different on the cars electrical system?"
I believe the assumption was to be made that an amp running at 1 ohm is "most likely" going to be class D, while an amp at 4 would "most likely" be a/b
"so you want to run at 4ohm rather than 2 or 1? higher the ohm the better?"
as long as the amp is stable at the given impedance there shouldn't be much of a difference. Measurable maybe, not audible.
Username: Carguy
Post Number: 5972
If you had a choice between 4ohms and 1ohm, then it's better to run the amp at 4ohms. Not only is there less strain on the amp and power supply, it runs much cooler.
Username: N2audio
Lawrence, Ks USA
Post Number: 1210
comparing amps of equal power -- a class d running at 75% eff at 1 ohm vs a class a/b running at 60% at 4 ohms -- the class D will run cooler. Excess heat definines efficiency.
If you're talking about a slash or xenon, then I'd agree with you, but even then the differences are pretty slight.
West palm, Florida
Post Number: 3393
but say you have two class d amps one does 400@4ohm and the other does 400@1ohm
basically they are both going to be the same. if the amp running at 1ohm is designed to run that low its going to be the same. now with some cheaply built amps it may get hot or may shorten the life span of it, but thats the risk you get when you buy a cheap amp
Username: Matt12490
California USA
Post Number: 1757
I think he is trying to decide between a class D and a class a/b amp. If that is the case, get the class D because it is more efficient which will strain your charging system less.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4193
factor would be efficiency. I'd run it at lower loads. IS cheaper and is the same when it comes to audible issues
Username: Carguy
Post Number: 5977
If you're talking about class D amp, then 400w@4ohms is the better amp when compared to 400w@1ohm. Think about for a sec, it's a tricky question/answer.
West palm, Florida
Post Number: 3400
why would their be a difference though isaac, if the amp is designed to run at 1ohm and if of decent quality its not going to be over heating or anything. only thing i can think of is more THD but it will still be low and i really doubt such a small amount would be noticable
Username: Zackattack
Kazoo, Mi Us
an amp will always put out more watts at lower impedences (lower Ohms). the more watts put out the hotter the amp will get. it is better to run at the lowest impedence so the amp isnt trying to stop amps from coming through, and overheating. it doesnt matter what class, mono or not... correct? the amount of watts matters more to the speaker.}
Username: N2audio
Lawrence, Ks USA
Post Number: 1212
Zack, more reading, less typing
I'm with you Mat - but we're getting down to opinions at this point so -- whatever floats someone's boat.
Username: Blainew
Post Number: 2181
heres the deal, as long as a speaker is RECIEVING 500 watts, it will be the same. an amp that does 500 watts at 1 ohm, on a one ohm speaker will sound the same as an amp that does 500 watts @ 4 ohms on a 4 ohm speaker
but
an amp that does 500 watts at 1 ohm, will always be louder than that same amp @ 4 ohms
Username: Blainew
Post Number: 2182
also to make thinks way easier, just dont worry about it and run your subs @ the lowest ohms your amp can handle (most times 1)
youll get the most power, for the least money, and who cares how hard the amp is working, if it was made to go 1 ohm, then it will work at one ohm
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 1073
wow blaine. if you wouldnt have made it bold or put it in a different color font, I wouldnt have understood it. haha
Username: Blainew
Post Number: 2183
hehehehehe
Username: N2audio
Lawrence, Ks USA
Post Number: 1219
"an amp that does 500 watts at 1 ohm, will always be louder than that same amp @ 4 ohms"
Easy now...JBL, JL, PG ??
Username: Carguy
Post Number: 5982
Before you all go overboard, there was a valid reason why I said 400w@4homs was better than 400w@1ohm. Take any amp and look at the spec. I'll give you an example, Audiobahn A8000T. It's 400w rms @ 4ohms, 800w @ 2ohms. If you run that amp at 4ohms, it runs cool and efficient. Push that to 2ohms and it gets hot. Depending on ventilation, could even cause thermal shut down.
The main reason however was this, 400w amp @ 4ohms will almost double in power @ 2ohms, and @1ohm, double that. Now an amp that's giving 400w@1ohm is operating at it's maximum capacity. That same amp would probably give 200w@2ohms and 100w @4ohms. You could say on paper, 400w@4ohms and 400w@1ohm are the same, but in reality, they're not. One will be more efficient than the other (same type and brand of amp).
Maybe I was the only one that saw the tricky question about 1ohm vs 4ohm amp. Who knows, but just wanted to point out the difference.
Username: Juliob
Post Number: 4200
if you read my post, it says pretty clear about efficiency.
I have to say i'm impressed with boss. Their orange subs (750w rms), i heard two in a camry 2002 with a boss blade 3000d wired at 1 ohm. They don't require big boxes, they're optimized for small sealed enclosures. And damn, i saw a lot of roof flexing, it was loud and decent Sq. In a better box, that would have been an awesome cheap setup.
Boss is improving... hehe lol!
West palm, Florida
Post Number: 3402
makes sence isaac but to be fair with a decent built amp say ARC is doing 400@1 its not going to be over heating and i dont think that would be an issue at all. over heating seems to only be a problem with cheap amps. look at the IA20.1 the run at very low impedances but from what cannan has said dont get hot at all.
but i guess what it comes down to, well to me anyway is it may not be 100% the same but it is close enough
