Question
Username: Tremor1127
You aint wangin till y...
Post Number: 913
can you have a beefy alternator but a regular car battery and it work for maybe 4000 watts? until you get batteries or get batteries first?
Username: Jblanford
Post Number: 472
well it depends on what you do...are you gonna drive around with your system on or are you gonna compete with the car off ? if your gonna have the system on with the car on then an alt and an UPGRADED battery should be good, but if your gonna compete the car will be off so you will definitely need some batteries for that
Post Number: 914
just jammin, car on, dont know which to get right now to keep the most power to two 2kw memphis amps... big alternator, or two optimas...
Username: Jblanford
Post Number: 473
big alt and 1 kinetik
Username: Trey4sports
Post Number: 509
100% alternator, your car uses the current from your alternator when your engine is running, then when it is drained it goes to battery...get a good iraggi alt
Post Number: 915
ok, this was all asked for a friend who thinks he needs batts before alt.
hes got a stock suburban, 4 fi Q 15s, 2 2kw memphis amps and stock elec system...
he thinks he needs 2 optimas in the back with his stock alt...
Post Number: 917
all this talk... i need to get my alt...
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 329
ya you do!!
btw, do u got ur amps yet?
Post Number: 918
he has the two 2kw amps...
as far as me, i have my amp for my new subs...
Midland, Texas U.S.
Post Number: 331
ohhh i jus kinda skimmed through
Post Number: 919
i do it all the time, haha...
