Username: Basssquared Post Number: 199 Registered: Nov-06
Wednesday, February 21, 2007 - 21:52 GMT will 2 L7s sound twice as loud as 1 L7 since theres two of them or does it not work that way? i have two l7s and ive only hooked up one so i was wondering if when i hook up the other one it will be twice as loud or only a lil bit louder?
Username: Snarl2004 Audioque 12 SD2.5s,
Earthquake P...
Post Number: 508 Registered: Dec-06
Wednesday, February 21, 2007 - 21:54 GMT u'd prob get like a 3ish db gain. noticible louder but not double
Username: Drivingreckless DD 9515f,
Post Number: 2962 Registered: Apr-06
Wednesday, February 21, 2007 - 21:59 GMT to be twice as loud audibly u have to gain 10 dbs
Username: Nickb4247 Post Number: 243 Registered: Dec-06
Wednesday, February 21, 2007 - 22:08 GMT If you simply add an L7, but don't increase the total system power, you will only gain 3 db's(roughly). If you add an additional L7 and double the power of the system, you see a gain of around 6 db's. Like driving said, 10 db's is an audible doubling. Look at it this way, each db is a 10% increase in sound audibly.
Username: Basssquared Post Number: 200 Registered: Nov-06
Wednesday, February 21, 2007 - 22:11 GMT so since my amp does 700 at 2 ohms wich is one l7 and then 1200 at 1 ohm wich is 2 l7s will it go up 6dbs or just 3?
Post Number: 2965 Registered: Apr-06
Wednesday, February 21, 2007 - 22:16 GMT ~6db ^theoretically(not always true)
Username: Basssquared Post Number: 201 Registered: Nov-06
Wednesday, February 21, 2007 - 22:21 GMT so driving seems like you know a lot about dbs and i know it all depends on the install but how many dbs at the lowest point do you think ill be hitting with those two l7s in a ported box with 1200 watts rms?
Post Number: 2971 Registered: Apr-06
Wednesday, February 21, 2007 - 22:27 GMT get a TL im not a meter
Username: Matt12490 California
Post Number: 1730 Registered: May-05
Wednesday, February 21, 2007 - 22:27 GMT Can't even answer. Since it all depends on install, with your installation skills you could hit between 30-170 dbs
Username: Basssquared Post Number: 202 Registered: Nov-06
Wednesday, February 21, 2007 - 22:31 GMT how much ar TLs and where can you get them at the closest thing ive found to one is a really gee boomstick at walmart that only metered up to 130 dbs
Post Number: 2973 Registered: Apr-06
Wednesday, February 21, 2007 - 22:43 GMT lol TL-600 new
Username: Trey4sports Post Number: 515 Registered: Sep-06
Wednesday, February 21, 2007 - 22:44 GMT they will set you back a couple hundred bucks, idk where to get em but im sure a vet around here knows
Username: Bump05 CashMoney,
15 Hd3
Post Number: 946 Registered: Aug-06
Wednesday, February 21, 2007 - 22:45 GMT driving dont know sh!t
Post Number: 2974 Registered: Apr-06
Wednesday, February 21, 2007 - 22:48 GMT love you to spl... ill be over tonite for my daily blow job
