Component amp
Username: Kyle7560
I'm going to be purchasing a set of crystal sscs components but before i do i need to know if they will work with my amp. I'm very new to car audio and i don't know if i can hook components up to a 2 channel amp or if i need a 4 channel. I have a rockford p4002 if its possible to hook the components up to the 2 channel amp could someone please let me know how i can do this.
Username: Logan__tille
Imortal Box Building
Post Number: 5956
whats the rms on thoes speakers?
Username: Kyle7560
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4168
kyle. go to www.the12volt.com and hit the link woofer wiring.
Is basically the same, but if you connect 4 speakers to a 2 channel amp, you lose the fade option
