Peal n seal
Username: Fatkid
tonawada, Ny
Post Number: 124
any one ever use it? does it make a difference? i went and looked at it last night and it does not look thick enough to do any thing but i could be wrong
Username: Tremor1127
You aint wangin till y...
Post Number: 881
i have it all in my car.
it works wonders for rattles, to actually deaden sound much you need to apply it in some layers. use a butane torch to heat it and work with it when applying, one that you buy at a hardware store, the one bottle will do your car plus some friends. and you cant smell it once it is in...
Username: Frkkevin
Post Number: 3090
actually a basic hair drier heats it up hot enough .. thats what i use when i work with it.. and yes it works very well considering the price..
Post Number: 882
i heard a hair dryer worked well too...
im one of those people who have more butane torches than hair dryers though...
i didnt even know i owned a harmonic balancer, but i sure found one when my crank pully took a crap over the weekend... ;)
Post Number: 883
errrrr... harmonic balancer TOOL
Username: Frkkevin
Post Number: 3092
i know all about it :-) .. i've rebuilt a 440 magnum from the ground up.. car audio is not just my thing lol :-)
Username: Fatkid
tonawada, Ny
Post Number: 125
how much of a difference in db does it make?
Username: Adddisorder
West palm, Florida
Post Number: 3223
impossible to say
