Need help with amp install
Username: Kariya762
Liberty Township, Ohio U.S.A.
Post Number: 8
After lookin in my trunk i realized that the person i bought my car from had already had an amp and had the wiring to it. I know that it was an amp because i knew the person i bought it from. The wires are there and i saw them run through the car. I didn't pop the hood to see if they were still connected, but i do remember touching the end of the wire. figured i would have gotten shocked?? Do you guys think the wire is safe to use. it's only about a year old. this is my first car and first system so if i don't use these wires how can i redo it? thanks
Username: Rosrock2000
Notre dame!USA
Post Number: 279
redo what? Use the kit if its big enough for the amp you wanna put in... dont waist something useful:-)
Username: Skibum12189
Cleveland
Post Number: 260
Make sure most everything visible looks right, hook it up to your amp, if it works, keep it, if not, redo or do some troubleshooting
