I thought I knew ohms law?
Username: Usask8er1
15 Orion H2 powered by..., 4 15 IDSPL &... 15 INCH WANGERS
Post Number: 618
http://cgi.ebay.com/Orion-Concept-97-3_W0QQitemZ110087897184QQihZ001QQcategoryZ1 8796QQrdZ1QQcmdZViewItem
"his amp will run .0000776 ohms which means you could hook something like 16 or 20 speakers"
Never knew that was even possible as an ohm load
Username: Johnfiac
IL Afghanistan,...
Post Number: 1287
haha bs thats basically 0ohms... that would basically be like attaching a wire in the + output right to the - terminal... i mean a wire with a tad bit of resistance.. LOL... and that would make massive heat.
Username: Bernymac
Cambodian
Post Number: 1995
lmao, well guess what a little bit of research can do for you. here look at this. and its true!
https://www.ecoustics.com/electronics/forum/car-audio/163184.html
Username: Johnfiac
IL Afghanistan,...
Post Number: 1290
eitherway the amp is pretty useless.... you would need to run so many subs to get the ohms that low and you wouldnt get much power.. and the amp more then likly cant hold that imdependance very long... if what i seen was right it said something about 30second burps..
Username: Bernymac
Cambodian
Post Number: 1996
well that doesn't matter. its a collectable. back in its time, it wasn't a useless amp.
Username: Adddisorder
West palm, Florida
Post Number: 3081
damn thats a sweet amp
Username: Southernrebel
Post Number: 4344
That amp is identical to the HCCA2100...just in a silver case.
It was built just to "cheat" in USACi and MECA. (2w amp :-))
Username: Van_man
Boston South, MA
Post Number: 1908
Acually, 512 4 ohm loads. Imagine 512 Sony 6x9 wired into it. Lol. But they would only be at 2 watts each.
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 1286
^^ haha. We'll put al the forums subs together and get some power outta that b!tch...
