Older 12 W3v4 (I have two one not working)
Username: Messiah88
Post Number: 16
I was wondering if there is a way to fix subs or when they go their just gone forever.
I was playing some sublime and one of them just stopped working the other works without flaws.
I tested the subs at home and the same thing just wont play any music.
Had both of them on a 500/1 JL amp so I dont think that I was over pushing it I think that they are rated at 300 a piece RMS
Any help would be appreciated
Thanks
Username: Notoriousroc1
Post Number: 35
take it out of the box and check the connections
Username: Messiah88
Post Number: 17
That was the last thing that I did and still nothing
I hooked both subs up without the box and still no sound
