New member Username: Z1truthFontucky, Ca. Post Number: 3 Registered: Jan-07 | Hi guys, I'm ticked at Adire. I made up my mind to get 2 Brahma MKIV D4 10's over the IDMax subs and the owner Dan Wiggins says they are out of stock and aren't going to make any anytime soon!!!!!! Then I find out the IDmax's won't fit in my limited enclosure for the 350Z as they need a 9.625" mounting hole and the largest this enclosure can accomadate is 9.250" mounting hole! This enclosure has 2 separate .70 sq ft chambers, 9.250 mounting hole and a 8.5+ mounting depth. The Brahma would have been perfect....BUT damn their customer service! On their Adire website there are a lot of CS complaint's! Then the IDmax mounting hole is 9.625"! Damn!!! For power I'm running 2 PG Xenon X600.1 amps, one to each sub so I'll have a true 600wrms to each sub! So who do I go with now boys and girls!!!! I'm looking at both the Elemental Design eD 11Ov.2 Subwoofer which really fits the amps power....OR.....the FI SSD 10"/or F1 Q 10". I like F1 Q better than the SSD because of the excursion and I want SQ first but LOUD! I like my rock vibrating the hair on my head and moving my mirrors around! What do you pro's here think would be the best choice for my setup or do you have any other suggestions?????? |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 5069 Registered: Feb-06 | SSD, not enough power for the Q |
Gold Member Username: AdddisorderWest palm, Florida Post Number: 2914 Registered: Jan-06 | RL-I or aresenals |
Gold Member Username: Logan__tille[:-]15 Wangers Club[:-] Premier Member Post Number: 5071 Registered: Feb-06 | Yea^^^ |
New member Username: Z1truthFontucky, Ca. Post Number: 5 Registered: Jan-07 | Do you have a RL web address???? Never heard of them ?!?!??!? |
Gold Member Username: Denali_on_22sSSX, Tenneki US of A Post Number: 1033 Registered: Feb-06 | SSD woudl be legit... if you got bigger amps the Qs would be good. The company isnt RL it's soundsplinter. Search soundsplinter audio and it shoudl come up. Looks like it will be a really clean setup! |
Silver Member Username: OneracistguyTWO EGG, FL USA Post Number: 206 Registered: Sep-06 | www.soundsplinter.com |
Gold Member Username: CenusHicksville, Ohio Post Number: 2850 Registered: Jan-05 | maybe some crystal comps(i think their 600wrms), or maybe some eclipse ti's. |
Silver Member Username: Razzeldazzel06Post Number: 159 Registered: Jan-07 | you guys think two Fi Q's are better then two image dynamic id max's overall????? |
Silver Member Username: Lil_jonPost Number: 406 Registered: Jul-05 | only one way to find out bobby I will buy which ever one you do not like |
Silver Member Username: Razzeldazzel06Post Number: 161 Registered: Jan-07 | ??? |
Silver Member Username: MgbcsLincoln, Nebraska Post Number: 261 Registered: Dec-06 | Bobby...this is the same question you have been asking for the last week. Everyone who wants to contriibute their opinion has already done so, and as you found from the other post, people are getting tired of answering the same question over and over again, only to get b!tched by you if it's not the answer you want. It's getting really old. Here's the answer to your question, because you must have a hard time recalling. https://www.ecoustics.com/electronics/forum/car-audio/317347.html |
New member Username: Z1truthFontucky, Ca. Post Number: 6 Registered: Jan-07 | Ah yes Bobby...... another thread Hi Jacker eh! |
Gold Member Username: CtmikeCt. Post Number: 3106 Registered: Feb-06 | fuc_k bobby just buy something already. you have almost 200 posts and thier all from the same question. STOP WITH THE SAME QUESTION AND BUY A SUB ALREADY! anything, it doesn't matter, just get something. |
Gold Member Username: James1115Use a simple... Post Number: 8928 Registered: Dec-04 | lol Mike those amps have enough power for the 10 Q's atleast for now |
New member Username: Z1truthFontucky, Ca. Post Number: 7 Registered: Jan-07 | So James you think my amps will be able to get those FI Q 10"s sounding good and loud? Logan said not enough juice?!?!?!and go with the SSD's. I really want fairly loud SQ. |
Gold Member Username: James1115Use a simple... Post Number: 8938 Registered: Dec-04 | yes those amps will get them going, and there is always room for upgrades in the future, possibly a kicker 1500 or something along those lines. Those PG amps are nice they will do the job, especially since you are running on the large side of sealed for those subs you wont need as much to get them bangin. |
New member Username: Z1truthFontucky, Ca. Post Number: 8 Registered: Jan-07 | Do you think the Kicker Amp is good clean power??? I've had some people try to steer me away from that amp! That's why I bought the PG Xenon's, but I can take them and swap! |
Gold Member Username: James1115Use a simple... Post Number: 8946 Registered: Dec-04 | you cant go wrong with Kicker, I dont know who told you that but they are wrong. Kicker makes a great underrated amp. |
New member Username: Z1truthFontucky, Ca. Post Number: 9 Registered: Jan-07 | Maybe I'll go with the Kicker KX2500 then. |
Gold Member Username: James1115Use a simple... Post Number: 8951 Registered: Dec-04 | ABSOLUTELY |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1457 Registered: Apr-05 | Glen, If you want to go with the ID max's, may I suggest to double up the entire baffle all over again, and/or just have some phase alignment spacers mounted over the current cutout with a larger 9 5/8" cutout to fit your ID max's. It aint over yet bud. You can do it. |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3449 Registered: Feb-06 | bobby shake and bake |
Gold Member Username: James1115Use a simple... Post Number: 8957 Registered: Dec-04 | good idea Mix |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3057 Registered: Jul-06 | if you dont chew big red, then f_ck you lol |
Gold Member Username: James1115Use a simple... Post Number: 8958 Registered: Dec-04 | thast movie was GREAT |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3451 Registered: Feb-06 | shake and bake and remmebr not to travel back to tijuana |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3452 Registered: Feb-06 | dint liked it too much kind of sucked i only liked the parts when his friends took his wife and where the two of them keep sayin shake and bake. |
Gold Member Username: Extrmndor3Sit and Look pretty Post Number: 3453 Registered: Feb-06 | u all should go watch undisputed 2 that movie its cool |
New member Username: Z1truthFontucky, Ca. Post Number: 10 Registered: Jan-07 | Ya know I was thinking about that earlier!!!! There is light at the end of that tunnel eh???? Altho the FI Q's would like my sealed box size better?!?!?!?! |
Bronze Member Username: Z1truthFontucky, Ca. Post Number: 11 Registered: Jan-07 | Ya know I was thinking about that earlier MIXNEFFECT!!!! There is light at the end of that tunnel eh???? Altho the FI Q's would like my sealed box size better?!?!?!?! |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1461 Registered: Apr-05 | Give Scott Atwell a call. Show him this thread. See what he thinks of your space inside the box. He has been spotted arround here you know. https://www.ecoustics.com/electronics/forum/car-audio/314995.html email me at Scott@FiCarAudio.com and Ill let you know. |
Bronze Member Username: Z1truthFontucky, Ca. Post Number: 12 Registered: Jan-07 | Mixneffect......you put e-mail me at....and I'll let you know......at the bottom of the thread? Are you Scott? |
Gold Member Username: MixneffectOrangevale, Ca. USA Post Number: 1463 Registered: Apr-05 | No No No That was a copy and paste. Scott wrote that in the pasted link above. If you read the thread, you will see Scott wrote it to someone regarding FI questions. |
Bronze Member Username: Z1truthFontucky, Ca. Post Number: 13 Registered: Jan-07 | Thanks mixneffect! I appreciate the help there bro. And by the way I P.E.E. standing up also only using one leg! LOL! |
Silver Member Username: 04redmach1Columbus, GA USA Post Number: 325 Registered: Mar-06 | 2 SI BM's would be pretty nice I can give you a little deal on them. Shoot me an email. Kevin lowhz01@yahoo.com |
Bronze Member Username: Z1truthFontucky, Ca. Post Number: 14 Registered: Jan-07 | WELL>>>>>> after MUCH MUCH contemplation the 2 PG Xenon 600.1 amps are going to be replaced with a Kickers KX2500 amp for better compatability with the subs that I'm liking. In my 1992 300ZX I running a Kicker XS100 competition amp at 1Ohm to 2 12" Kicker L7's in a sealed box, so I like it loud, crisp and clear. I want this 2 10'' sub box in my 350Z to sound and hit at least as hard and clear as my 300ZX's if not better.That's what I'm shooting for! :D So that being said, I'll think I will try to fit 1" spacer/phase(?) ring over the existing 9.250" mounting hole on the 350Z box which should now open it up to accomadate the bigger sub diameters as long as they are compatable for the .70 cuft space. I now can either go with the FI Q 10's, IDMax 10's, or the Eclipse SW9102's now. But which one to choose?!?!?! I'm sure the Daytons and SI BM's are great subs, but I need more power..... |
Bronze Member Username: Z1truthFontucky, Ca. Post Number: 15 Registered: Jan-07 | Oh my god! I just found the TC-3000 10" sub! What a gorgeous design! It fits all my criteria too!!! Anyone here have any reviews that you could point me towards???? |
Gold Member Username: CtmikeCt. Post Number: 3144 Registered: Feb-06 | can't remember reading alot about the tc's here. i have read alot of people over at www.caraudio.com talk about them. |
Gold Member Username: Nyyfan13Fi SSD USA Post Number: 3124 Registered: Jul-06 | caraudioforum.com reps tcsounds like its the bible... |
