never used the massive amp but owned the Raa1000 which was a VERY SWEET amp ,had 3 40A fuses on it & played real clean/loud & did not seem to drain current even though with all those fuses
but since that massive is 1500wrms right ? - & if ur getting both same price i would choose the 1 with more power ......
oh yeah, and my p3000.1's are two p1500.1s strapped. I had each sub hooked up to its own channel. What I'm saying is that each sub was like hooked up to its own p1500.1 getting 1k each bc I had them wire at 2ohms since my subs are dual 4's.
yeah rovin their the same price. its just id get the same amount of wattage out of either because i dont have the electrical to run it at 1500. Thanks though the Mb quart does look nice. glad to hear from someone who had personal experience with it thanks
ooh wow lol. i bet MA came after to try to mix people up for a good brand. i saw some good prices on some massive amps. what companies are they comparable to?? kicker? better than kicker? i might have to pick one up
Ive got the MB Quart raa1000 and raa2400 very nice amps very clean. It says it will do 1k at 1ohm at 14.4 volts but i think they are a lil underrated. Never had expereince with the massives tho. But if they are the same price id go with the massive in case you need extra power down the road. By the way what kind of deal are you getting on them?
Well i was looking at massive audio amps and this website came up and they didnt sell any decent brand amps. All legacy, pyle, ect. Best brands they had were pioneer and PG amps and in the middle of no where massive... so does that mean they arent the best of quality?? They do have some VERY cheap prices..
