Box alright?
Username: Snarl2004
Post Number: 126
This box is for a 12" HD3 getting 1000rms. The box is 2.79 net cubic feet tuned to 35hz.
Username: Frkkevin
Post Number: 2834
I'd make your port a tad wider.. 3.5" would work.. you were a little low on port area IMO.. but yes it would be fine
Username: Devastation101
Audioque SD2.5-ville, HENDERSON, NC VP of 15 Wan...
Post Number: 866
I agree with Kevin^^^ what kinda vehicle is that going into?
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 953
make sure your port isnt going to be too close to the side wall of your vehicle... At least 4"
Username: Snarl2004
Post Number: 127
its going into a chevy s10 extended cab truck. the port is in the middle of the truck so its not within 4 inches of anything. so you think 3.5 would be good for the port?
