New radio problem
Username: Jonesp
Post Number: 147
i just bought a new radio cda-9830 i believe and my subs dont really hit until i turn the volume up to like 20 and there still not as loud. when i had a factory it slamed. any suggestions?
Username: Rosrock2000
Notre dame!USA
Post Number: 216
Gain is to low? Make sure both rca's are connected. Adjust bass on radio(normally called head unit if aftermarket). If it has a lowpass filter kinda play with that maybe...all i can think of.
Username: Jonesp
Post Number: 151
my gain is probaly too high right now its at 1.5 bass is all the way up. rca is the little blue one right? i only have one connected to the fuse box. i think lowpass is on 120
Notre dame!USA
Post Number: 221
nono... thr blue wire is your remote wire.. it turns on the amp when the hu starts up. RCA's are the 2 cables that run from your amp to hu. Should have like red and white ens or something and they both should be hooked to your head unit.
