Eclipse SW9122 12" SUB SUBWOOFER TITANIUM
Username: Littleguy
Post Number: 125
Can anyone tell me if this is a good sub? Eclipse SW9122 12" SUB SUBWOOFER TITANIUM.an audio store said i would only need one and he wanted 600.00 for it, i found one on ebay for 309.00 new.
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 4832
yea, its ok.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2444
put around 1500 watts to it and let it go. And yeah dont pay 600 for it , a local shop has a 12'' for $325 ... ebay will probably be your best bet though
Username: Littleguy
Post Number: 126
I have a Hifonics BXi1606D 1-Channel Amp, it says 1100 watts RMS@2-ohms 1600 watts@1-ohm, will that work, Thanks for your info. Would just one woofer work or should i get 2?
Username: Sw9152
Michigan
Post Number: 876
i got a 15" ti on a rf X7 pushing about 1600wrms and it pounds. the only downside is the small surface area from the huge suround, but it hits the lows amazing with a little over 3.5" excursion.
Username: Sw9152
Michigan
Post Number: 877
im real happy with it. worth 300 bucks.
Username: Littleguy
Post Number: 127
Which is better,JL 12w7 or the 12" 9122 eclipse?
Username: Skibum12189
Cleveland
Post Number: 109
13w7 and just buy a used 500/1. itll be loud as hell
Username: Renegadesrun
Lafayette, IN US
Post Number: 555
The 13w7 will laugh at the 500/1, tell it to take its underpowered azz back to the factory, and not to come back till its grown up to a 1000/1.
