EQ setting?
Username: Theivan
Dawson Creek, British Colu... Canada
i want a really deep bass eq setting to really push my sub. Amp is a JL 500/1 I have an Infrasonic Sensor between 15 and 60 hz and for my bass eq i have:
Q(bandwith) = 0.5 to 40
Center Freq = 20-80
Boost (dB) = 0-+15
mostly for rap music. Any ideas?
Username: Nd4spd18
Southeast PA
Post Number: 703
You don't want to be using bass boost to adjust the volume of the bass.
If you add boost after you set the amps's gain, your amp will clip when you turn up the volume.
Need to Register?
Forgot Password?
Enable HTML code in message
