Fi's New Driver
Username: The_image_dynamic
San Diego
Post Number: 176
All specs listed below are for the standardversion , daily tolerences, with no options.
10"
D1 D2
Re 1.5 3.0
Fs 41.5 40.3 Hz
Qms 5.43 5.58
Qes .37 .34
Qts .35 .33
Mms 155 164g
Vas 12.8 12.8l
Sd 310 310cm^2
Bl 12.8 19
Spl 85.8 85.7 1W/1m
12"
D1 D2
Re 1.5 3.0
Fs 38.7 37.8 Hz
Qms 5.79 5.93
Qes .39 .37
Qts .37 .34
Mms 177 184g
Vas 30.9 30.9l
Sd 480 480cm^2
Bl 12.8 19
Spl 88.0 88.4 1W/1m
15"
D1 D2
Re 1.5 3.0
Fs 35.1 34.5 Hz
Qms 6.23 6.34
Qes .47 .43
Qts .44 .40
Mms 232 240g
Vas 81.6 81.6l
Sd 810 810cm^2
Bl 12.8 19
Spl 90.6 90.7 1W/1m
18"
D1 D2
Re 1.5 3.0
Fs 33.1 32.5 Hz
Qms 6.43 6.54
Qes .53 .49
Qts .49 .46
Mms 280 290 g
Vas 169.7 169.7 l
Sd 1210 1210cm^2
Bl 12.8 19
Spl 92.5 92.6
Ill get a couple more pics up and update this post in a little bit...
Thanks...
Scott
San Diego
Post Number: 178
They named it the BL.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3510
thats quite a high fs.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 76
Is there pricing info or RMS handling out on them yet? I was exploring the Fi website, but didn't see anything. I'm excited
Username: Southernrebel
Post Number: 4029
the 15" is $279 shipped....rated 1000-1500w i think...but it will have add-ons like the BTL
Post Number: 4030
Here is a post the Scott (owner) made:
"OK... sorry, my computer is being a PITA the past couple of days... and I have a new one on the way, so bear with me :-)
2 new driver pics.
(IMG:http://i66.photobucket.com/albums/h244/mozvegas/Small%20Fi%20pics/New1201.jpg)
(IMG:http://i66.photobucket.com/albums/h244/mozvegas/Small%20Fi%20pics/New1202.jpg)
Based off of the same pair of magnets as the Q, but using a solid pole like the BTL so we can do the pole chamfer and full cooling, a few coil up grades, and a "SPL" version with the tighter tolerences and heavy BTL leadwire.
Pricing will start at the same prices as the Q line:
10" $249
12" $259
15" $279
18" $309
Power handling for the standard version is 1000W, with the ability to go up from there with different coil and cooling options added.
It is designed to fill the gap between the Q and BTL for low power SPL, or daily driving apps. So a "fully loaded" whatever the name of it will be sub will come in right at what a standard BTL will do (but still for a couple less $$$ and a higher qts and lighter package).
Its not a Q v2.0 or anything like that :-) It is a harder hitting daily driver with less Xmax and a little more mechanical durability.
Name and more pics to come ;)
Thanks...
Scott
Username: Mgbcs
Lincoln, Nebraska
Post Number: 77
So it's the same base price as the Q? ONly there will be further options?
Username: Mr_kebo
Albertville, Al USA
Post Number: 1143
yes
Username: Mgbcs
Lincoln, Nebraska
Post Number: 78
Maybe this is a bad question, but is anyone planning on picking one up right away?
Username: Ctmike
Ct.
Post Number: 2930
i'm waiting at my computer right now with my credit card in hand:-)
Username: Tremor1127
Wishes there was an 18...
Post Number: 688
im getting 2 18"s...
Username: Mgbcs
Lincoln, Nebraska
Post Number: 79
lol that's awesome. So will the information post later tonight or something? I cant wait!
Post Number: 689
its just a little at a time right now... scotts computer is being homoerotic right now...
Username: Mgbcs
Lincoln, Nebraska
Post Number: 81
ok...I see. Well, I guess I'll just have to be patient lol. Tremor....what are you powering these babies with?
San Diego
Post Number: 179
Scott sent some people all the info and they can't post it at SSA either, Marshall is over there right now so whatever happens he will probably post it here. Anyways, we have most of the info in this thread and the Fi web site doesn't look like it will be updated until tomorrow at the earliest. Scott said he might set up an alternate ordering method for now. Stay tuned.
San Diego
Post Number: 180
"Standard sub comes with a round wire aluminum coil, rated at 1000W RMS. You can up the thermal capacity by adding the flatwind coils, pole chamfer, and full cooling.
You will also have a choice of either the "Daily" or tighter "SPL" tolerences as well as the option for the extra heavy leadwires (as used on the BTL's) Although I would add the caveat that they should be reserved might be reserved for SPL only as they can be noiser for daily driving purposes. Xmax is 21mm."
San Diego
Post Number: 181
Pricing on Upgrades
Pricing starts out same as Q ++ options
Flatwind - 20$
Pole Chamfer - $10
Full Cooling - $40
BTL Leads - $5
Spl / Daily option is free, but is based off of usage.
Post Number: 690
Ben, they will be powered by a Concept CD-2410 (2410rms @ 1ohm, rating). 240amp alternator, yellow top for amp, all 1/0 wiring.
i will eventually buy a cheap SUV just to add 2 more and build a wall for all 4 and power them with a couple good SPL amps... not a f@rt car, just a groundpounder, maybe some tiny hairtricks...
Post Number: 691
"Spl / Daily option is free, but is based off of usage."
i dont get this. explain...
Post Number: 4032
That just means the gap will be tighter for the SPL option.
You get more of a chance of a coil rubbing, but you also get more motor force applied to the coils...usually results in alil more efficiency.
Post Number: 692
thats all i needed to know, thanks...
Username: Goodie_goop
Midland, Texas U.S.
Post Number: 132
:-)woo hoo im ordering a 15" later this week:-)
Username: Nyyfan13
Fi SSD USA
Post Number: 2553
that thing looks nice
Username: Johnfiac
IL Afghanistan,...
Post Number: 1048
sombody let me hear a dammn FI sub!@!!!!!! They should call it the FI BTLFTP "BTL FOR THE POOR" lol j\p guys :-D
Who is around the south side or south burbs of chicago that has any FI subs? Preferably fully loaded BTL's in a nice setup.... i want to get subs, think the BTL's look great but hear the SQ isnt really that good and its almost impossible to hit about 150 with a single sub setup, althought that is hard to do, i heard the DD9915 can easily do it. Im so stuck in choosing what sub(s)\brand to go with...... i hate trying new brands when dishing out so much money! BLAH!!!
Username: Johnfiac
IL Afghanistan,...
Post Number: 1049
I didnt mean for that to sound like im dissing FI.. but then i might just be trying to compare to almost completely different subs to eachother... i compared the 9915 with the fully loaded BTL... never heard either but form what i heard was mentioned above... i really want to hear each of the subs.... dd9515, dd 9915, and FI 15BTL fully loaded.
Username: Andrew571
Post Number: 592
I bet the new line can take 2krms loaded, easy. :P
Username: Nyyfan13
Fi SSD USA
Post Number: 2556
to any fi rep or anyone who knows the answer...
when is fi gonna get stickers? its not that big of a deal, im just curious...thanks whoever knows and answers
Username: Rosrock2000
FI SSD 12 , MI USA
Post Number: 122
yeah i want one kinda bad.. even though the average car audio peeps dont know what it is..
Username: Dmm2005
DD Audio ORION, Warren Count... USA
Post Number: 431
i want he Fi shirt steve meade has!
San Diego
Post Number: 182
****************** BL SERIES ORDER INFO *****************
For the time being orders will be taken via Paypal payment for the new BL Series. To place an order, please send payment to: BLOrders@FiCarAudio.com
In your Paypal payment please be sure to include the cost of any/all options you want as well as a list of what you are ordering in the notes section. Also make sure that your listed Paypal shipping address is the one you want it to go to... and a phone number is never a bad idea either.
If you have any other ordering questions regarding the BL Series, please feel free to email me at BLOrders@FiCarAudio.com. All other tech orders or questions regarding the BL or any other products should still go through the Sales@FiCarAudio.com address.
Thanks...
Scott
Username: Thugshizz
Long Beach, California
Post Number: 80
I have a ?, how is the SQ of the BL compare to the sq of a Q or SSD ?
Username: Nyyfan13
Fi SSD USA
Post Number: 2587
the BL is suppoed to be spl...i beleive
Midland, Texas U.S.
Post Number: 136
no one knows for sure yet.....but not supposed to be as good as the Q...prolly better then the SSD or around the same...but i dont really know
id hafta say closer to the BTL on SQ, but you didnt mention the BTL so i uno if that helps
Username: Thugshizz
Post Number: 82
Well I hear the it will have more output than the Q but will it sound as good.
Midland, Texas U.S.
Post Number: 137
no...but it shouldnt sound too bad
your best bet is to wait for someone to install and listen to it and listen to wat they say about it
Username: Spandmh1
Tunnel hill, Ga CANT WAIT... Usa
Post Number: 149
anyone think itll bump good?! i want to see it in action.
Midland, Texas U.S.
Post Number: 138
i REALY hope it will bump good
Username: Cashby
Post Number: 163
how much is a fully loaded 12" BL sub??
Username: Gh0st_31
FL USA
Post Number: 162
$259 - starting price
Options:
Daily, SPL, or Universal* - no charge (Dont use the SPL for daily)
$20 Flatwind (D1 and D2)
$10 Pole Chamfer
$40 Full Cooling
$5 Heavy Leadwire (But not recommended for daily)
Grand total of $334
Username: Cashby
Post Number: 164
why shouldnt i use spl for daily? alsow at would be louder a 12" Q or a Normal 12" BL ??
Username: Gh0st_31
FL USA
Post Number: 163
well depends on what you listen to and want from your system. Q more directly to SQ and BL more directed to SPL. Both would be great.
Username: Cashby
Post Number: 165
and wat are the sealed box recommendations for a 12"............same as Q ????
Username: Cashby
Post Number: 166
do u have any of that info yet? and also what is the universal one that u mentioned above..is that just like spl and daily combined?
Username: Gh0st_31
FL USA
Post Number: 164
not sure truthfully, but i would assume yes
Midland, Texas U.S.
Post Number: 140
ya i wanna know what the universal is all about too...but i think scott said in his post that the SPL version will not last as long if you use it for daily
Username: Livin_loud
18 of Love Fi Audio
Post Number: 822
For sale: Fi 18" Q
lol
Username: Nkknutson
Post Number: 21
so if i get one of these and they come D1 and D2 which do i choose to wire the sub to 2ohm. i'm only getting one sub thanks
FI SSD 12 , MI USA
Post Number: 136
nate, get the dual 1 version.. wire it series.
Username: Nkknutson
Post Number: 22
ok one more question sounds like this sub can run between 1200rms to 2000rms "2000rms is loaded" i think im going to get the cooling and flat coil so maybe some where around 1500rms or so and was wanting some ideas for a amp could be 2ohm or 1ohm? i'm gitting the daily sub. thanks
p.s. need some help don't know many amps only heard of kicker but feels like i'm paying some extra for the name.
18 of Love Fi Audio
Post Number: 826
kicker makes great amps. use hifonics for a tight budget, but get one basically right above your desired RMS. orion, jbl, re, and rockford fosgate are all good as well, but you'd be good with a kicker...
Username: Johnfiac
IL Afghanistan,...
Post Number: 1057
you might want a extra battery to. 1500rms is pushing it on stock charging system, unless you already upgraded, get the D1 and wire in series for 2ohm, get a mono amp that does around 1500rms@2ohms and you should be good.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 68
Most of all of these questions can be answered directly by FI on their forum.
Username: Fi_car_audio
Hades, NV
Post Number: 95
Denim to the rescue ;)
