1994 Isuzu Rodeo
Username: Allen
Temple Hills, MD US
I just installed a later model 1996-7 Isuzu AM/FM/ Cassette radio with CD/CH accessory. I had to change the wiring harness (cut and splice). Everything works fine but I am not able to get my dash lights to come on. All wires were used and connected. Do I need a ground to the chasis and a jump wire to the dash lights?
Username: Leew
XXXX!!WWWW, Yokosuka, ... SPESNAZ. ...
Post Number: 1039
you need a jump wire to the illumination controller!
BTW. if you wanna check out your wiring again,then go to my web. I made ready for you all the wiring radio 94,radio 97( illumination controller 1994 included!).
Username: Allen
Temple Hills, MD US
Thanks, Jen. I have reviewed the wiring diagrams that you sent me. Don't want to short anything. Which wire should the jump wire be run from?.. red/green (radio) to red/green (controller)
Username: Texlady
I am trying to replace the factory speakers (5" round). I ordered some online. Even though they are 5" round, they are just a tiny bit too large. Do you have any idea where I can purchase some that fit? Thank you.
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1323
Because they are 5-1/4"
Sorry, none of the items in 5-1/4" Speakers fit your car.
Go to Outfit My Car to see the products that fit your vehicle.
Show me all the 5-1/4" Speakers
this is from from http://www.crutchfield.com/cgi-bin/ProdGroup.asp?g=51800&cm_re_o=k wufEzM*l5TN99*5TDvoii
maybe you need to find a speaker adapter for your car!
Username: Leew
Post Number: 1324
http://www.installer.com/
they can help you too!
