What can i use to keep resin from stickin to a plastic mold?
Username: Dmm2005
DD Audio ORION, Warren Count... USA
Post Number: 464
Www.15inchwangers.com
Post Number: 9447
masking tape
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3525
ding ding^^
Username: Dmm2005
Post Number: 466
and i can remove the tape from the inside of my mold? im makin a mold of an aeroport and want to be able to pull it off
Post Number: 9448
the masking tape just peels right off the resin.
Username: Dmm2005
Post Number: 467
ok cool thanks!!
Username: Van_man
Boston South, MA
Post Number: 1771
Wax paper works very well. If you have it flat, the resin will be flat and no finish work. I used to make hood scoops like that. Lay out the wax paper in the mold. Pour in resin and then some cloth. Let it set up. remove from mold, trim edges, paint.
