1990 jeep cherokee tweeter help
Username: Jeepxj
I got a 1990 jeep cherokee and i need help re-installing the tweeters because i had an 90 watt am that aint working rite now and i tested the tweeters on my sub amp and they worked but i can't use my sub amp cause it is only a 2oo watt amp and i have 2 10" subs so i can't use it i just want to go straight to my head unit because i really need to listen to some music when i drive.
THANKS ALOT FOR WHOEVER HELPS ME
Username: Adddisorder
West palm, Florida
Post Number: 2796
well if you hooked tweets to a sub amp then you probly killed them. they cant handel anything below probly 2k at very low volumes.
and you need a crossover you cant just hook them up
Username: Jeepxj
well i have two crossovers but i just wanna skip the 4-channel amp and plug it into the head unit
